#1961
Old 04-01-2022, 07:57 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by cgeise View Post
I looked at the graph again what gear you running -- ?? and what happened on the 2-3 shift??
3.89 rear gear with a 33.5" tire.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1962
Old 04-05-2022, 08:49 PM
Originally Posted by Dragncar View Post
He has one of the coolest Pontiacs on planet earth.
Put a LS in her and she qualifies as a "who cares" car as far as myself and lots of other people are concerned.
I have even seen 60s Chebbies at the track who put a LS under the hood trying to go fast, think they are cool. Coil on plug and all that.
Then they run a 12 and I chuckle at them asking them why ? Ruin the car to run a 12.
I know, I know, they can make a ton of power with boost.
I will pay twice as much to not go as fast in a Pontiac than be one of "them".
Calm down..calm down.. I'm just stirring the pot.. I don't believe in cross breeding at all..said it many times..
I would take a 2 barrel 389 in a Pontiac over a 1000hp LS..
  #1963
Old 04-06-2022, 02:41 AM
Dragncar Dragncar is offline
A little pot stirring going on myself. I figured you would respond quicker, slowing down my man ! Yep, cross breeding sucks, it goes against the laws of nature.
  #1964
Old 04-07-2022, 12:48 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Don't badmouth all "crossbreeds". I've run Pontiac engines in:
'37 Buick
'60 Ford Falcon
'57 Chevy BelAir
'57 Chevy wagon
'59 GMC
'83 Chevy Suburban ('Bandit' built by Wangers)
Mini-rod puller- numerous V8 Pontiac engines, carbureted/injected/N/A/blown, gas/methanol
Lakester- DOHC hemi Pontiac, blown methanol
The Following User Says Thank You to Jack Gifford For This Useful Post:
  #1965
Old 04-07-2022, 01:02 AM
Getting back at them is always good.
I would like to build a 69C10 4x4 with a 455 myself.
  #1966
Old 04-07-2022, 03:05 PM
I have been involved with a couple of of Chevy Suburbans with 455 cid Pontiac engines.
Chassis is just a way to transmit the torque and power.
Same deal with Tempest vs Lemans, vs GTO.
  #1967
Old 07-01-2022, 09:53 PM
RAIV-Z's Avatar
Well... 2022 so far hasn't been positive so far due to parts delays and issues found during re-assembly. The heads are back out for a bit of welding on 2 intake ports "minor cracks that don't go through to the exhaust port" and to address the new valve seat installation issues noticed after head tear down and further inspection.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
  #1968
Old 07-01-2022, 10:30 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Question
If it was easy everyone would be doing it. Thanks for the update and good luck with the maintenance.
PONTIACPOWA' TTF!!!
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
  #1969
Old 08-26-2022, 09:25 AM
67'7F6'Bird's Avatar
"RAVEN YOUTUBE CHANNEL"
https://www.youtube.com/channel/UC21...TRqShGQ/videos
  #1970
Old 08-26-2022, 12:56 PM
I have two friends who have done that swap also Jack and the vehicles
perform perfectly.
Would love to find a clean Suburban and do one for myself.
  #1971
Old 08-26-2022, 02:16 PM
  #1972
Old 08-29-2022, 06:06 AM
tininjun68's Avatar
tininjun68 tininjun68 is offline
Link didn’t work. Just me?
You know me, "Safety Forst"
68 GTO-Verdoro/Black/Black, what else was available in ‘68? Has to be longest resto in history.
69 GTO Vert-Liberty/Blue/White Top, 4spd, match #’s
68 Mustang FB-Green/Black (Bullitt)
  #1973
Old 08-29-2022, 06:24 AM
Stuart's Avatar
Stuart Stuart is offline
Originally Posted by 67'7F6'Bird View Post
That link doesn't work - is this the video you wanted? https://www.youtube.com/watch?v=jCABq0K2_Wk
The Following User Says Thank You to Stuart For This Useful Post:
  #1974
Old 08-29-2022, 08:57 AM
  #1975
Old 10-14-2022, 08:39 PM
RAIV-Z's Avatar
What I do at the track when not racing.
Name:	relaxing at the track.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1976
Old 11-19-2022, 11:21 PM
RAIV-Z's Avatar
Heads are at Marcella Manifolds to be welded up and refreshed for hopefully a successful 2023 season.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following 2 Users Say Thank You to RAIV-Z For This Useful Post:
  #1977
Old 11-21-2022, 11:01 AM
scott70's Avatar
scott70 scott70 is offline
What ETs are you hoping for this year? Didn't know if you had a certain goal in mind. It's pretty damn good for 3600+ lbs.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
  #1978
Old 11-21-2022, 05:31 PM
RAIV-Z's Avatar
Thanks! I'd like to run anywhere in the 6's with most of what I have now and then determine next steps.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1979
Old 12-16-2022, 11:52 PM
RAIV-Z's Avatar
We'll (John) be welding up all 8 cylinder walls so we can increase the boost in 2023. Drive train upgrades will also need to be considered.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1980
Old 12-17-2022, 12:12 AM
PAUL K's Avatar
That's a lot of work. Sometimes it pays to be conservative with a high end boost head. It pays dividends with low maintenance and longevity verses little additional power.
Go fast, see Elvis!
