Old 09-15-2022, 09:38 AM
Stan Weiss's Avatar
I have things lined up dot to dot for starters. The .005 short chain fits like a glove. If I end up needing to advance it, the crank gear will probably need a puller to come off. The one I have isn't thin enough to get between the block and the chain, but I'll cross that bridge if I get there.
If you have to pull the gear you don't want the timing chain to be on the gear.
Stan
Pontiac Pump Gas List
Old 09-15-2022, 11:34 AM
The cam snout should be sticking out of the gear?
Do you have the cam plate on?
Probably need to pry the cam forward and slide the gear on more.
Old 09-15-2022, 12:19 PM
Verdoro 68's Avatar
You can mic the snout and balancer, see if that's going to be stubborn too or not. If you look at the one pic of my mishap, you can see I lightly peened the snout end where the key 'line' is, which helps when lining up the key/keyway during install.
Good idea. Lining up the gear with the key is a pain. I marked the snout with a sharpie but it wears of quickly. Will check the balancer.
Good call. I don't want to damage or stretch the chain. The chain is a very tight fit so I can't remove it off the cam gear without moving the crank sprocket in tandem. Any recommendations?
Yes, it should and I will.
Ken
'74 Ventura 350
'69 AMC Javelin SST
