Old 09-21-2022, 08:37 PM
I see labels that say "Built in the USA from domestic and globally sources materials", so at least they are assembling here, but are some of the components being used not as good as they could be?
Something else to ponder on. Just because it's made offshore, China, Brazil, Japan, Sweden, Germany, Italy, etc, doesn't mean that its an inferior product. Believe me those Countries and others have the capabilties of making parts just as good as we could do here........just not at the price point we are willing to pay for them...........
Well stated, Cliff. Of the Cummins 6B and 6BT forgings we used to regrind some of the better ones were from Brazil. The best were from Great Britain and Germany. The worst? Mexico. U.S. and Japanese forging were on par with the Brazilian forgings.
Dr. Thomas Sowell
Old 09-21-2022, 08:44 PM
I agree, but you know how the mentality is around here, if it's not USA it's junk, or, I'll only buy USA product. You hear that one a lot. LOL
Well those goofy laws that vary by state sure seem to leave a lot of grey area.
On the flip side there is a lot of junk out there too, we all know that.
A lot of the aircraft recip engine parts we used were made in Brazil (valves, valve springs, valve spring retainers, and valve keepers), Germany ( pistons and piston pins) and Great Britain( oil pump gears, rocker arm bushings, connecting rod bushings, connecting rod bolts…even SPS bolts, and engine bearings). ALL of these parts have to meet the OE specifications and pass an FAA inspection. ALL nations produce garbage as well as well made parts.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 09-21-2022, 09:20 PM
Brentco's Avatar
Brentco Brentco is offline
The FTC enforces “Made in the USA” claims under its deceptive advertising laws. They apply to products sold anywhere in the United States. The rule is that "all or virtually all" of the parts and processing must be of U.S. origin. The product should contain no — or negligible — foreign content. Claiming “Made in the USA” for foreign lifters machined or assembled in the U.S. would certainly violate FTC regulations.
https://www.ftc.gov/business-guidanc...e-usa-standard
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
The Following 2 Users Say Thank You to Brentco For This Useful Post:
Old 09-21-2022, 09:30 PM
P@blo's Avatar
P@blo P@blo is offline
Anything posted on a public forum is not going to be current by any stretch of the imagination.
Even Topline is a crapshoot along with your crappy roller lifters so it looks like we are all in the same boat. Welcome to the jungle gentlemen...
The Following User Says Thank You to P@blo For This Useful Post:
Old 09-21-2022, 10:33 PM
I agree with that. That's what I was getting at in Cliff's post. Just have to sort through it. Just because it's from a foreign country doesn't necessarily mean it's a bad part.
Australia makes some really nice products too. ICE ignition is one that comes to mind.
https://youtu.be/XqEydRRRwqE
Old 09-21-2022, 11:18 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That's interesting. There is a lot of copying of head castings done in China too with various different names attached.
Yes, our Government gives China a lot of leeway on copyright infringement. But you are screwed royally if you design a part for a diesel truck that improves power but messes with the function of the EGR valve.
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 09-22-2022, 02:47 AM
64speed's Avatar
64speed 64speed is offline
I’m not an expert by any stretch but I just received my Crower Cam Saver lifters and the machining looks great.
Old 09-22-2022, 08:48 AM
PAUL K's Avatar
Can you post a picture of the lifter body?
Go fast, see Elvis!
Old 09-22-2022, 08:56 AM
chrisp chrisp is offline
Harley-Davidson motorcycles sold in the United States are not actually made here, but assembled here. Harley contracts manufacturing of parts to plants located all over the world, including Germany, Italy, Taiwan, Japan, and Mexico.
Old 09-22-2022, 09:00 AM
RocktimusPryme's Avatar
With most of this stuff, especially in the hot rodding world, it seems the best most of us can do is buy parts based on reviews from people we trust.
Just pick your expert, or better yet a consensus of experts, trust their opinion and roll the dice!
The Following 2 Users Say Thank You to RocktimusPryme For This Useful Post:
Old 09-22-2022, 09:03 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Harley Davidson Twin Cam engines used Hylift roller lifters till 2001, then went to cheaper Delphi parts. They are NOTORIOUS for lifter noise and several companies make parts to help quiet them down.
I put Hylift roller lifters in mine plus the "rocker lockers" and it turned it from a "thrashing machine" to a sewing machine as far as noise is concerned. Going by memory 4 roller lifters were right at $160 back then.........
Old 09-22-2022, 09:26 AM
track73 track73 is offline
I was told at one time the most "American" made car was Honda..
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 09-22-2022, 12:54 PM
P@blo's Avatar
Yeah and those are probably mabe in Canada lol
Old 09-22-2022, 03:13 PM
Shiny Shiny is offline
Watch Topline's automated manufacturing video and you can understand how the cost of making a lifter (or anything else) might be less in another country. Not sure if this reflects their current process, but I am sure their investment in custom equipment would have to be spread over a LOT of parts. And the market for old Pontiac parts is probably two levels below "a LOT" in their world.
https://youtu.be/lLx_2UKcjS4
Old 09-24-2022, 09:13 AM
64speed's Avatar
I can’t get a good picture of the machining swirl on the bottom
The Following User Says Thank You to 64speed For This Useful Post:
Old 09-24-2022, 10:36 AM
I'm not seeing an oil hole, so I went to their website, still don't see anything and their description on their "cam saver" lifters are vague, as in they say nothing at all. So why are they called cam savers? I don't see anything different about them.
I used the Comp version that they called EDM at the time and they actually have a hole on the face of the lifter to squirt pressurized oil right onto the cam lobe.
Old 09-24-2022, 10:45 AM
Formulas's Avatar
Formulas Formulas is offline
one time in the early 90's i put in a new cam and lifters, small cam stock old springs decided to spin the oil pump before i put in the pushrods
WTH glitter of copius amounts came flowing out of the tops of the lifters when pressure hit them
i have a reversable air powered 950 rpm drill motor i keept spining the pump until the glitter stopped and i was comfortable all the oil went through the filter a few times because at that point the cat was already out of the bag
lifters have been sketchy for a long time
  #38
Old 09-24-2022, 10:49 AM
Steve C. Steve C. is offline
Crower CamSaver Hydraulic Flat Tappet Pontiac V8
https://crower.com/hydraulic-lifters...ontiac-v8.html
And here with no band around the lifter body:
https://www.summitracing.com/parts/cro-66056x3-16
However JEGS states, "Product images may differ from actual product appearance."
https://www.jegs.com/i/Crower/258/66...4aAlPtEALw_wcB
Old information here:
  #39
Old 09-24-2022, 10:52 AM
Yep, and if you click on "more information" nothing extra, no info on the lifters. There is literally no description about the lifters at all that says they are anything other than a regular flat tappet lifter. No hole on the face of the lifter either that I can see. 64speed's picture of the lifters he received doesn't show a hole either.
So what makes them a "cam saver" ???
  #40
Old 09-24-2022, 10:55 AM
Here are the lifters I used, and you can clearly see the .012" hole in the face of the lifter. Squirts oil right on the lobes of the cam.
https://www.compcams.com/tool-steel-...chevrolet.html
