#1421
Old 09-02-2022, 05:27 PM
Gach's Avatar
Gach Gach is offline
Here’s video of Mr Pontiac at Norwalk in his 67 white GTO with combination I mention earlier, recap on the combo 461 ci, out box E-Heads just clean up. performer RPM intake, Q’jet and Crower 60919 cam. Scroll to 55 minute into the video, this is his 11.60 pass, with a block of wood under gas paddle to keep it from going faster then 11.60’s. Real nice street cruiser.
https://youtu.be/Ag1a7Q-ENW4
Old 09-02-2022, 05:35 PM
Gach's Avatar
He went grocery shopping, on his way home, he decided to see what it’ll do at the track. LOL
Old 09-02-2022, 08:58 PM
grivera's Avatar
grivera grivera is online now
Nice run
Will Rivera
  #1424
Old 09-03-2022, 03:07 PM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Maybe I missed but What are the duration and lift differences between your old HR and the 60919?
Also what do your heads flow? I’m curious what the cam change will do in terms of power? And what the drivability differences will be?
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
  #1425
Old 09-05-2022, 09:12 AM
64speed's Avatar
64speed 64speed is offline
I dont have the card right here before me right now. Its substantial thought. Like the difference between almost 600 HP and maybe 450 if I am lucky
  #1426
Old 09-05-2022, 02:15 PM
I’d say your likely to be in the 500 to 525 hp range running the RAIV cam. A stock RAIV 400 has been dyno tested at 425 hp even though it was rated at 370 by Pontiac. Seriously, a RAIV making only 4 hp more than a 366 hp RAIII D-port engine?
Your good cylinder heads will get you there even without a monster cam. Giving up 50 to maybe 75 hp at the peak that you wouldn’t been using often anyways is a small price to pay for something easier to drive and more reliable.
The Following 2 Users Say Thank You to b-man For This Useful Post:
  #1427
Old 09-05-2022, 03:42 PM
Gach's Avatar
Exactly ! and good torque numbers !!!
Old 09-09-2022, 08:43 PM
64speed's Avatar
Got my new block today. 72 casting
  #1429
Old 09-10-2022, 07:44 PM
64speed's Avatar
So excited. Got my valve springs today
  #1430
Old 09-10-2022, 08:26 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
David have you considered the Johnson hydraulic roller offered by Butler? My builder is discouraging the use of any flat tappet lifters.
  #1431
Old 09-11-2022, 02:56 AM
64speed's Avatar
Yes I have but I went this way for a variety of reason not the least of which is cost. Very few companies have any roller cams available right now, I hear excellent things about Crowers quality control, the Crower tech gave me step by step instructions and made me very comfortable, and with the money saved I can purchase other things I need to complete the build.
I feel pretty confident about this being as I am not using a radical cam or an exotic valve train.
  #1432
Old 09-12-2022, 06:03 PM
64speed's Avatar
Have everything but pushrods rockers and lifters. Engines coming out Wednesday,, block is going to machinist Friday or Monday
  #1433
Old 09-22-2022, 02:04 AM
64speed's Avatar
Got a little behind with illness but block should be going to machine shop next week. Haven’t totally taken the old one apart. No older than they are can I reuse the head and main studs?
  #1434
Old 09-22-2022, 10:32 AM
tom s tom s is offline
Yes on the head studs,for your power level you should not need the studs for the main.If all the main bolts are stock just use them and save yourself some money.JMO,Tom
  #1435
Old 09-22-2022, 12:38 PM
geeteeohguy's Avatar
I'm afraid that ship sailed 3 or more years ago.
Jeff
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post:
  #1436
Old 09-22-2022, 12:57 PM
64speed's Avatar
I already have main and head studs. Just want to reuse them.
  #1437
64speed's Avatar
Got rockers and lifters. Gotta get pushrods when the time comes
  #1438
Old 09-22-2022, 01:06 PM
64speed's Avatar
Does this mic location look ok? It’s for the hands free calling on the radio
  #1439
Old 09-22-2022, 01:07 PM
Formulas's Avatar
Formulas Formulas is offline
the only savings will be the new block should be aligned honed or at least checked with studs in place because of different clamp loads,
use stock bolts sell studs for savings
use studs work block for them = more $$
  #1440
Old 09-22-2022, 01:12 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I wouldn't like it there. Maybe tucked in up in the corner of the dash or something less conspicuous. IMHO
