Old 09-23-2022, 08:52 AM
Half-Inch Stud Half-Inch Stud is online now
Is a matter of trrsional forward-backward accelerations. As if a rubber crankshaft. Not a matter of Balance.
Moreso a matter of friction between the pulley& damper surfaces with clamping force by the 4-bolts.
I ended up installing with a bit of wet spraypaint.
Old 09-23-2022, 09:44 AM
P@blo's Avatar
P@blo P@blo is offline
The bolts you used look like they are SS not steel. Looking at the link you posted acklands says steel with a black oxide finish?
SS strength is not as good a steel and would ditch those if I were you. The different SS gradings can really vary in tensile strength and their ability to hold your pulley.
Both grade 5 or 8 will solve your problem. A good washer under the bolt will help as well.
Old 09-23-2022, 10:57 AM
imposter's Avatar
imposter imposter is offline
Default balancer
should i get another stock one, and now i have to get it balanced, nobody around anymore to do that kind of stuff
Old 09-23-2022, 11:14 AM
Did you take a good look at the back of pulley at the center hub hole? Was it riding the radius and actually never flat on the balancer?
Old 09-23-2022, 11:19 AM
FYI I can’t remember the last time I saw a stock balancer that spun true they almost always have a slight wobble. I have a half dozen stock balancers here with great looking rubber and none of them are perfect true.
Old 09-23-2022, 11:54 AM
imposter's Avatar
Default balancer
so what one do i buy
Old 09-23-2022, 12:14 PM
AG's Avatar
AG AG is offline
Get a Pioneer stock replacement or SFI version.
Old 09-23-2022, 04:09 PM
25stevem's Avatar
25stevem 25stevem is offline
What to do you ask?
Send yours out to the Damper doctor in CA and get it rebuilt.
I do stuff for reasons.
Old 09-23-2022, 05:27 PM
1_Wild_Cat's Avatar
I used Damper Dudes (also in CA) on my Buick. I was happy with them.
Old 09-23-2022, 05:38 PM
P@blo's Avatar
Sorry guys, I confused the OP and now realize it was another member that posted the link for the bolt specs. Formulas also mentioned the washers previously
Old 09-23-2022, 08:53 PM
johnta1 johnta1 is online now
One other thing is the end of the balancer snout looks like it's galled. Could be from the rubber but could also be because the balancer needs to be tighten to specs. (150 lb/ft)
Old 09-24-2022, 05:29 AM
25stevem's Avatar
160 ft lbs.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 09-24-2022, 10:30 PM
imposter's Avatar
how do i keep the motor from turning is there a tool besides the flywheel turner
