Wow that's a lot of mpg to lose
.... It would be a larger increase in power percentage wise.
My emergency genset is 5000 watts, or 41.66 amps, it has a 13 HP engine on it. Would it get by with a 5 HP engine, absolutely not.
When the electric fans kick on at a modern car idling, the engine lugs down 150 to 200 RPM before the computer idles it back up. You can only do so much work with a certain amount of energy expended, whether it's being direct driven by belts, or it runs a generator that spins a motor. If there is much less HP being taken by electric fans, then they're not doing the same amount of work, moving the same amount of air. It's going to be pretty difficult to say that an electric fan moves the same amount of air as a belt driven fan because every electric fan manufacturer doesn't use the same formula to determine CFM. We do know that in a street driven Pontiac V8 will seldom run cool with most electric fan systems, but when you go back to a belt driven fan it will run cooler. You're clearly moving more air with the belt driven fan, it's apples to oranges. You don't typically gain any energy advantage by running a fan with an electric motor, if it's actually doing the same amount of work as a belt driven one. I don't know of a laws of physics that you gain energy by using a different mode of energy transmission, be it fluid/hydraulics, electric, or mechanical drive, such as a belt. I don't see that you can do the same amount of work, with less energy being expended, or less drag on the engine. There is no free lunch. |
No he always took the power steering belts off to race, that was .06-.07 itself I believe.
Let’s not forget some facts here gang!
Other then headlights and 2000 watt sound systems electric fans eat up the most current out of a Alternator. But your fans should not need to run for that long atleast in a street car once your above 30 mph, I mean if your cooling system does not need to be crutched by having the fans running at that point.
I do stuff for reasons. |
Not with todays cars/electricial loads. Some fuel pumps will take 20amps to run which is why most new stuff will PWM a pump, plus new cars run electric power steer pumps. Hell even IGN1A coils can chew up to 10A per coil with a LOT of dwell & boost. Radiator fans typically chew 12-15A each and again, today they PWM them.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
Yes, but the OP I don’t think is talking about a new production car, so once again a thread here has gone of the rails for the sake of chewing the fat.
Yes. And the Alternator efficiency (at cruise) is booked at 65%. I think more HP is lost during Accel.
5 HP = 3728.5 watts Then add friction to the process and a safety margin. Stan
Stan
Since my 455 never even thought about running hot, and was actually a PITA to get up to temps I tried switching from a clutch fan to electric a few years back.
The trade off was not worth it. You are no longer driving the fan and robbing crankshaft horsepower for cooling, but the drain on the battery and required work from the alternator offset the gains. The alternator was working so hard to keep the battery charged that I'd "spin" or "twist" alternator drive belts at the track at high RPM's. That NEVER happened with a clutch fan set-up. I also killed the battery a few times in hot summer days idling around the pits and the cooling fan running and had slow cranking to refire the engine to make a pass. I really didn't see enough improvement in ET or MPH to offset the negatives so put the clutch fan back in place and ditched the electric fan set-up........
On my Pure Stock drags RA4 GTO,, I put a toggle switch to bypass alternator load. No difference in et or speed.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
| The Following User Says Thank You to J GLASGO For This Useful Post: | ||
Most who have posted forgot the efficiency you mentioned. 1Hp may equal 746 Watts but an alternator is not 100% efficient so output does not equal input due to drive ratio (pulley size), frictional losses and heat.
Triple Black 1971 GTO |
| The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
"To generate 140 amps at 13 volts requires 2.44 hp. Volts times amps divided by 745.7 equals HP. "
More accurately, 2.44 HP is the equivalent output; the required mechanical input is more like 5HP given the efficiency of about 50%. George
| The Following User Says Thank You to george kujanski For This Useful Post: | ||
I went from getting around 320-330 miles per tank to 270-280 miles per tank. It is pretty crazy how dramatic the change is. The Mechman died once a couple years back and while it was out for repair I switched back to the 160 amp alternator and my gas mileage came right back.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
I have pulled the field wire and did not see a difference either.
#38
Seems crazy how inefficient the car Alternator is rated 65%. Before knowing i would have assumed > 92%.
#39
Also as said above, a fan has to move a certain amount of air to maintain engine temps. This required energy should really be close to even between mechanical and electric fans. Otherwise the no-free-lunch principle would be violated.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
#40
