Old 12-06-2019, 01:38 PM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
Default 64-67 GTO Cooling Problems Solved!!
We all know our GTOs have a tendency to overheat or at least run hot all the time. Problem comes when the original non-AC owners put in bigger motors, install AC, etc...and only have room to fit a tiny 15.5" radiator. And worse yet, trying to find a usable AC radiator support could be harder than finding a needle in the middle of your backyard!
That problem is about to be solved...
Cold Case is working on an support adapter kit that will allow your non-AC support to accept the taller 17.5" radiator. This solves the problem of either finding a new support OR having to settle for a smaller radiator. Combine that with our Super Duty kits with 1.25" tubes and you'll be running cool in no time.
Prototypes are on their way to us so we will keep you updated with status and pictures.
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
The Following User Says Thank You to eric_cspan For This Useful Post:
Old 12-06-2019, 05:24 PM
Eric, will this adapter kit be available with a stamped lower rail section or just the extended lower corners?
Many lower rails on used early Pontiac A-body core supports are in horrible shape & new lower rails have to be fabricated.
Old 12-06-2019, 05:31 PM
eric_cspan's Avatar
Administrator
Don't quote me because it's not finished but I believe they are making the new lower rail section.
Old 12-06-2019, 05:34 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
It will extend to the lower rail section where the original two pieces connected. You'll have to drill out the old welds and replace with this lower section. Basically, you end up with a legit AC core support when done. The only difference is that the lower mounting brackets will be our kit we made years ago instead of the factory welded one found on original AC supports. If that bugs someone, then they should be looking for a REAL ac support.
Old 12-08-2019, 12:25 AM
64speed's Avatar
64speed 64speed is offline
Well I ordered the HO radiator a while back to use in my car but had to get the 15 cause my car was a non AC Tempest. It caused me to have to have a 66-67 radiator hose cause the hose side is swapped but I don’t care about that. My question is on a streetable roller cammed 467 with AC is the two extra inches make it worth exchanging the radiator and getting the kit? I have the 1.25 fin radiator already but it’s a 15. I will have aftermarket AC
Old 02-03-2020, 04:30 PM
eric_cspan's Avatar
Administrator
Working prototype...production now in progress!
ID:	531041   Click image for larger version
Old 02-03-2020, 05:50 PM
Ccass's Avatar
Administrator
Every motor is different. Every rebuilt motor is even MORE different. There's no way to know for sure. A lot of guys are fine with the 15" big core but some motors just run really hot. The fact that you have AC definitely adds to the heat quite a bit.
I can tell you that the tall radiator at 2" x 20" wide x 3" deep is a LOT more fluid.
Old 02-03-2020, 06:33 PM
JC455 JC455 is offline
Thank you for this, Ccass!!
This is exactly what I had asked for several years ago!!!!
John
IG: @crawdaddycustoms
Old 05-26-2020, 09:20 PM
1965gp 1965gp is offline
Is this currently available?
Old 05-26-2020, 09:49 PM
Ccass's Avatar
Administrator
Yes it is for 66 and 67. We think it will fit 1965 as well but have not tested it yet. All the usual dealers should be carrying this product but you can e-mail me if you are having trouble finding them. I'll get you taken care of.
[email protected]
We will also have a full AC radiator support for those that don't want to do their own conversion. It should be available in June.
Old 05-26-2020, 10:12 PM
eric_cspan's Avatar
Administrator
Ames is currently stocking these kits so support them! #P119VX
We are selling them also on our Cold Case site.
https://www.coldcaseradiators.com/pr...conversion-kit
You can search google for other dealers by the part number. RPE68L
Old 06-05-2021, 10:30 AM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Very cool! Has anyone installed one yet? Looking for some real world feedback.
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
Old 09-06-2022, 07:15 PM
mwgasman mwgasman is offline
[email protected]
New member here and sorry to bring threads back from the dead.
Did this ever get tested on earlier cars?
I just acquired a 1964 Lemans convertible with a 6 cylinder and a bad radiator. I'm planning on a V8 swap and A/C in the future and want to put in the 17.5" radiator now. So, I'll need to convert my core support.
Old 09-06-2022, 08:20 PM
Ccass's Avatar
Administrator
Nobody has ever tested a 1964 but I suspect the top panel is going to be different..
Old 09-06-2022, 09:29 PM
Thanks for the reply.
I’ll order the conversion kit from one of the dealers you supply this to and see what has to be done for it to attach to the’64 core support. I’m not afraid of the cutoff wheel or the welder if it comes to that.
Will report back.
Old 10-22-2022, 01:51 AM
I ended up not doing the conversion on a 1964 core support. I found an a/c core support.
