Old 10-24-2022, 11:35 PM
73 TRANSAM 73 TRANSAM is offline
I removed my booster on my 1050 dominator by screwing a screw on that banjo from the metering block side and pulling the screw with a vise grip. Then the booster just slides out from the top. Then just reverse the step for installation. I used a special grease that came with my kit. Not sure what is it, looks like a very thin red lube. Good luck.
Old 10-25-2022, 09:40 AM
Very common to do it that way and at one time you could buy the booster "retention" inserts, if you screwed on up on removal.
Old 10-25-2022, 11:16 AM
charlie66's Avatar
Im not trying to take mine out ..
My Half AN Injun.....
Old 10-25-2022, 12:13 PM
grandville455's Avatar
Sounds like u put a screw into the booster pin and removed the banjo with booster still inside, I'm talking about just removing the booster itself from the banjo, leaving the banjo and booster pin installed in main body, done it many times! I suspect charlie is still using gas sized holes in his 12 hole booster's and that's why its not entirely happy, I would enlarge them to .059
Darby
M/T 275/60 ET SS Drag Radial
Old 10-25-2022, 08:38 PM
Smile
I messed up on terminology. What I meant to say is the pins that locks the booster in place.
