#241
Old 11-02-2022, 02:16 PM
I say vacuum advance isn't necessary? Not sure if that was to me, but I've always said full manifold vacuum is the way to go.
Yes, metal to metal, and no, it won't leak. It's a machined surface torqued at 120, there's no seepage unless it's not machined right.
Ask Butler then if BOP, who makes the seal, isn't trusted.
https://www.bopengineering.com/seal_instructions.pdf
Just going to have to disagree on this one, please don't take it personally.
  #242
Old 11-02-2022, 02:23 PM
Good news: The last pass sealed the oil pan.
Bad news: I discovered the rear main has a small leak.
I had to trim the one piece seal to get it to sit down in the channel, and I never really felt 100% about it, so I'm not totally surprised it's leaking. I also read in some old threads that line honed blocks can have some trouble with the neoprene seals so that may be a contributing factor. Additionally, the #5 journal was also the odd one out in terms of bearing clearance (loose compared to the others) and required a different shell so something must be off just enough to cause a leak. I bought a BOP two piece just in case the one piece leaked, but now I'm wondering if the Best Seal graphite seal would be a better choice. From what I've read, they seem to be more forgiving but I'd have to pull the crank back out to install it.
How did you determine you had a rear main leak if it’s never been started up?
  #243
Old 11-02-2022, 02:25 PM
No, BOP tells everyone that vacuum advance isn't necessary, which is sillyness.
I didn't say I don't trust BOP, my point was when they make statements like that you sort of have to sift through what you know works and what doesn't and make your own decisions. Some of this stuff you just have to take with a grain of salt. Nothing personal taken bud, I just know what I've seen come through here, and what has been the solution. Not my idea, I gain a lot of those little tricks from other very knowledgeable engine builders over the years.
https://youtu.be/XqEydRRRwqE
  #244
Old 11-02-2022, 02:34 PM
Verdoro 68's Avatar
Tipped the engine back on the stand for a day and watched the oil drip out the rear. I first found an oil pan leak, and once I got that cleared up I found the rear main dripping too. I think I bungled the seal install. Pics from the disassembly are a few replies up.
Sounds like the BOP seal is the way to go with this crank given the serrations. I reached out to Butler to get their two cents since they put a lot of these together. I also asked about using a smidge of sealant under the rear main cap
Just to confirm, this is an Eagle aftermarket crank.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #245
Old 11-03-2022, 11:46 AM
Verdoro 68's Avatar
Via Butler:
We like the BOP two piece seal. Just need to make sure to follow the install instructions to make sure it’s installed properly. That’s the issue we’ve seen is people not following the instructions and having a leak.
Where the two seals come together you can add a little sealant to help with sealing. Also rotating them just little off from the parting line helps. Basically pushing one end just below the surface of the block while the other will be out of the block. The piece in the main cap rotated to match the block piece helps with sealing.
Interesting that they say to rotate the parting lines. I was reading a Buick site where they were using the seal and said the same. BOP instructions say you can do that, but they haven't found it necessary.
The BOP instructions say to "apply a thin film of silicone or anerobic sealer between the cap & block and anti-rotation holes only."
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #246
Old 11-03-2022, 12:26 PM
Via Butler:
Yes the anaerobic sealer works for that too. Why BOP tells people on the phone to not seal the cap yet will send instructions along that say otherwise is puzzling. Makes me wonder if they've had customers that just went overboard with it, or used the wrong type of sealer and caused problems.
I don't rotate the seals here either, I just keep the parting line with the block and use sealant from the seal face out to the edge of the cap.
I've never found any advantage to rotating the seal. A parting line is a parting line.
Never had one leak.
  #247
Old 11-03-2022, 12:39 PM
We only fill rotation holes and on end of seal as recommended have had no issues. We have used 1 and 2 piece seals the one thing I can say is 2 piece so much easier to install. My engine has had a 2 piece in it since 2012 and has been run hard with no leaks. Crankcase pressure is going to make your engine leak faster than anything else except for a complete gasket failure. The last rear seal we saw leaking was a two piece but after a little investigation we found out the owner had removed the pan and rear cap in car and slipped it in It failed miserably.
  #248
Old 11-06-2022, 07:26 PM
Verdoro 68's Avatar
The saga continues.
I misread his email and he said normally he'd recommend polishing the serrations, but since my crank is on the low end of the tolerance he didn't want to do that. Instead, he recommended I sand material from the end of the seal (rather than the radius) to get .020 preload, so I did.
I sent pics of the seal fitment to Wade and he said I was on the right track so I proceeded to button everything back up. I put a tiny smear of sealer under the rear main cap between the block and cap and a tiny dab on the ends of the seal. I ended up installing the seal seam with the cap/block rather than offsetting it.
After a 5 hours tilted on the stand, I've still got a slow drip off the back of the crank The pan seal and the cap to block are bone dry, so it must be the seal. The oil is collected on bottom of the flange of the crank hub like it was before. It's not a huge leak, maybe one or two drips over the course of the 5 hours, but I'd obviously prefer not to see any leaks.
I cleaned everything off really well and will keep it angled for a while longer with the hopes that what I saw was just residual oil, but I doubt it. I know some folks have had some drips via the tip test only to have it seal up once it's running and in the car, so I'm wondering if I just roll with it and hope for the best. Frustrating.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #249
Old 11-06-2022, 08:27 PM
It's true, have seen it before as well, tip or other tests it may leak slightly, and once heat cycling a few times from running it doesn't leak in use.
I don't offset the parting lines of seal either, have never used the 1 piece.
I like the rope-type seals and have install of those down to an art. But those are not recommended with a crank that has no serrations.
  #250
Old 11-06-2022, 08:54 PM
Verdoro 68's Avatar
It's definitely the seal. I folded a blue shop towel and wedged it between the crank flange and the rear main. Came back in about an hour and it had wicked some oil.
I checked the journal again with my dial bore and didn't pick up on it being out of round. My guess is this leak has to do with the crank diameter being at the bottom of the specs for the seal, or maybe it's just oil seeping past the serrations like Wade said. The only other thing I can think of is maybe it's getting past the anti-rotation holes? I filled them level to the cap as best I could.
Not sure what to do here. Now is the time to make this as right as it's going to be. I have a graphite seal on hand but to confirm, those ARE NOT recommended for cranks with serrations, correct?
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #251
Old 11-06-2022, 10:01 PM
Oil will seep past the serrations when the engine is tipped. Generally you don't want to run those serrations with the BOP seals unless they are polished to some degree, so they don't eat at the seal over time. Those seals are designed for a smooth surface. The serrations are there for the rope seals, to keep them lubricated.
  #252
Old 11-06-2022, 10:08 PM
Verdoro 68's Avatar
Do you all think I’m better off with the graphite seal in this case?
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #253
Old 11-06-2022, 10:38 PM
tom s tom s is offline
Im 50/50 with the 2 pc seal,100% with the one pc and 100% with the Best Gasket rope.FWIW,Tom
  #254
Old 11-07-2022, 12:09 AM
Verdoro 68's Avatar
I probably read too much and got my signals crossed. I thought the Best Gasket was best for a smooth crank. I saw some cases (like this thread) where the graphite seal got shredded and thought it was due to serrations. That's why I tried the two piece BOP this time around. On the whole, the graphite seals seem to be much less finicky and have a higher success rate. I don't have a problem pulling this thing back apart if it will work with my crank.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #255
Old 11-07-2022, 07:11 AM
Agreed, there can be minor leakage past the hash marks even when everything is 'right'. I've noticed when engines sit parked for extended periods, this can become more evident.
I would have to go back thru my notes regarding if the Best rope seal is compatible with hash marks or not, all my memories at the moment are that I've always used the OE type ones that came with the Fel-Pro full engine gasket sets. Not the basic kit the 'premium' kits.
I would think a rope seal would work without hash marks as long as it has the graphite, but am not going commit to that at the moment. The hash marks were there to hold a touch of oil so the seal doesn't 'stick' to the crank when sitting for a period of time, or that's my understanding. (You can imagine, sticking is not a good thing). With that in mind, you can understand why the originals would weep a little right out of the factory, and might/can/is considered 'normal'.
If you understand that concept, you can clearly understand why there are 'anti-rotation holes' in the block/cap. When you pack a rope, pack hard in the areas of the hole, and concentrate on packing those areas first. You have to 'feed' the rope into those holes as you pack, accordion-ing the rope from the ends towards the holes. (If you can imagine that). Work from the parting lines to the center.
Also, I recall over the years the ropes included in those Fel-Pro kits went from an amber color to a more grey/black color, suspect that they started using graphite in them, not sure. I've had success with both though.
Packing the seal in the cap/block is a test of patience, crank has to be R&R'd multiple times to ensure you get the proper fit. It's a balance of drag and fit/clearance, but can say initially, there's more drag than one would think, required to make it seal right. After a number of heat cycles, it takes a 'set', and the drag loosens up some anyway.
Those 'custom' or intent-specific packing tools are garbage, using a large deep well socket (or similar item) to pack is what I've had most success with.
Ok, morning brain-dump completed, more coffee is needed...
  #256
Old 11-07-2022, 12:17 PM
Verdoro 68's Avatar
Here's how much it leaked sitting on the stand at an angle overnight. I can see the dribble of oil from the bottom of the main on the crank flange. I don't think this is going to disappear if I run it this way.
ID:	601835   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #257
Old 11-07-2022, 04:39 PM
No, like 3-5 drips at most overnight is about what's acceptable.
  #258
Old 11-07-2022, 04:50 PM
Verdoro 68's Avatar
Both Butler and BOP are telling me it's not uncommon to see leakage from the seal when tipped and I should be good to go if I followed the instructions. Just seems like a lot to me. I think the graphite seal would be more forgiving, but I'm not sure it's a better option with the crank serrations.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #259
Old 11-07-2022, 05:02 PM
AG's Avatar
AG AG is offline
I'm 100 % with the BOP (stock and aftermarket cranks) and 100 % with the Best using a stock crank. The Best is better than the two-piece in the Fel-Pro sets.
  #260
Old 11-09-2022, 05:37 PM
Super cool build! Should be quite stout when it’s all said and done. This stuff can be frustrating when you gotta redo the same operations over and over, but you’re almost there!
For reference:
Factory cast cranks had the serrations to to run the factory rope seal.
Many aftermarket cranks DO NOT have the serrations, in that case, you would run the BOP neoprene lip seal.
Cranks with serrations can run either seal type.
Good luck!
