Old 01-10-2023, 06:18 PM
SD455DJ SD455DJ is offline
Dan discovered that it has its original 4-Q-69 AC Delco spark plug wires on it still that definitely have a 'set' and also its original Delco cap and rotor...amazing. Dan also set the new cast iron intake in place...getting closer to looking more factory original...and running.
Dennis
Name:	Original 4-Q-69 Plug Wire.jpg
ID:	604892   Click image for larger version
Name:	New Intake in place.jpg
Old 01-11-2023, 07:05 AM
Kenth's Avatar
Kenth Kenth is offline
4-Q-69 date would be for 1970 vehicles.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-11-2023, 11:55 AM
Maybe they are 4th Quarter 68 wires ?
Instead of 4 Q 69 (70)
Either way he appears to have been a concerning owner.
And the car sure got lucky -AGAIN- when you guys came along.
Old 01-11-2023, 04:29 PM
Sorry, my bad, they are indeed 4-Q-68...2nd brain fart.
Thanks Kenth and BVZ!
Dennis
Old 01-11-2023, 05:26 PM
Dan's rebuilding a 7029268 Q-jet for the 350HO, the picture is a teaser with another Q-jet to make sure the fuel line (old original from a past rebuild) fits. Dan found an old original thermo-vacuum switch with the plug and hoses (5 fittings) to add to the intake as well as the proper pcv nipple and coolant temp sensor for the idiot light. He needs to rebuild the carb yet, so could be running by Friday! We also see through the fuel pump opening in the timing chain cover that the cam gear is a steel replacement, so scratch that off the list.
Dennis
Name:	'69 CustomS Q-jet.jpg
Old 01-11-2023, 05:32 PM
Does anyone know if this is an original factory tire (now the spare)? It's an 8.25-14 Uniroyal Laredo 4-ply rated (WW)? '69 appears to have utilized both tire sizing methods, numeric (like above) and the letter series (G78-14).
Dennis
Name:	'69 CustomS Uniroyal Laredo 8.25-14.jpg
ID:	604936   Click image for larger version
