Old 01-14-2023, 12:13 PM
bluejudge bluejudge is offline
Originally Posted by 242177P View Post
Just in case anybody gets stuck with an undersized post, they make repair shims. Never used them, just aware of them. HTH.
Thanks, I learn something new on here all the time…
The Following User Says Thank You to bluejudge For This Useful Post:
Old 06-29-2025, 08:59 PM
xsram67 xsram67 is offline
Default R-59 Turbo Start battery post fix.
I received my battery a few days ago and I also was discouraged by the + battery post. Here's how I made the fix. I took a aluminum ski pole inside diameter of 11/16"and cut a 9/16" piece off and de-burred the inside edges. Next I prepped the post by using battery post tool and emery cloth. Next I used soldering paste and coated the aluminum sleeve and battery post. I then placed the sleeve on the post and used my soldering iron to lay a small amount of silver solder on the top. I then used my Bernzomatic torch and heated the top slowly till the solder sucked down inside the sleeve. I immediately poured cool water over to cool it quickly. I then removed the sleeve and it looks perfect. Installed it in my GTO and fired it up.
