JL, so I understand. You have no PCV valve so the flow is unrestricted to the can and then to the intake manifold. I do see a breather on the drivers side. Is that unrestricted as well? Also, how do you think your setup would play with A/F ratios with EFI? I know you have spent a lot of time with Fitech which I also have.
There are no problems..only solutions. |
The breather has some foam in it to keep oil contained, but is otherwise open. I did not have to change anything in my tune when I made this change and have not witnessed any changes in my reported AFR's or my short/long term learn trims. The big thing this is doing for me is providing ventilation operation during high vacuum/high rpm situations where a stock type PCV valve would otherwise be closed.
Not from the change to the draft setup. What helped me the most in that regard is letting the EFI control the timing. Gained a full 2” of vacuum at idle with the ability to command up to 24* of advance at idle. The system idle stabilizes advance between 18-23 degrees usually.
| The Following User Says Thank You to JLMounce For This Useful Post: | ||
