Old 01-21-2023, 06:06 PM
Default Do 2019 Camaros have compact spares?
or a similar year?
Old 01-21-2023, 06:09 PM
tom s tom s is offline
I think it depends if they have run flat tires.Tom
Old 01-21-2023, 06:20 PM
jerry455 jerry455 is offline
My wife's 2017 2SS does not.
Old 01-21-2023, 08:33 PM
JLBIII JLBIII is offline
My 2010 SS did not have any spare.
Old 01-21-2023, 08:45 PM
1969GiPper 1969GiPper is offline
Did it come with a 12 volt air compressor and a can of tire puncture sealant?
The Following User Says Thank You to 1969GiPper For This Useful Post:
Old 01-21-2023, 09:52 PM
My wife ‘14 does have a compact spare.
Dr. Thomas Sowell
Old 01-21-2023, 10:40 PM
Pontiac Performance Author
My 2015 SS convert has a pump and sealer . I think the plainer models come with compact spares. I believe it has to due wheel size or brake size. My Cam. has 20" wheels w 14 " Brembo brakes
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 01-21-2023, 10:56 PM
limejudge69's Avatar
My 2014 RS had a spare tire. It also had 20" wheels. It did not have Brembo brakes
Old 01-21-2023, 11:26 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
The spare tire on late model Camaros is an option that the vast majority
built do not have.
Old 01-22-2023, 12:05 AM
^^^^ that is not what I wanted to hear...
Old 01-22-2023, 02:44 AM
Yes. It had that and the car battery mounted in the trunk. I never used the tire repair kit while I owned the car.
Old 01-22-2023, 08:14 PM
1965gp 1965gp is offline
What do you need it for? Fit over brakes?
Old 01-22-2023, 11:37 PM
yes, switched to a prototype design using 13" Corvette rotors and truck calipers - superb braking on a budget.
The older version I was using; 79 rear T/A rotors (11-1/4") and 69-72 GTO calipers worked fine but looked tiny in the 17" Bandit U109's... I also dispensed with the dual 9" booster and ran 1974-80 GMC 1/2 ton manual master - works fine even with rear disc.
Old 01-23-2023, 10:17 AM
Very cool. What about the G8? It might have come with a spare? I know the 04-06 GTO’s did but I’m not sure they are large enough for what you need?
Old 01-23-2023, 10:27 AM
Perhaps - it has the same bolt pattern...
Old 01-23-2023, 10:41 AM
04-06 GTOs have a metric bolt pattern.
The G8's are the same as the Camaro's the V6 powered cars come with a spare tire and jacking kit, the V8 powered cars have no spare tire, or jacking kit. They come with the air compressor and fix a flat.
And throw out the fix a flat if it is more than 3 or 4 years old, the cans have an expiration date, and can blow out. I had the one in my 2006 Solstice blow out shortly after I bought in it 2016. What a mess to clean up!
Old 01-23-2023, 10:44 AM
Skip: yes, they are 120mm vs. 120.65mm (4.724").
Not ideal but for a very short drive to a repair shop, acceptable. BMW's have the same pattern also.
CamerJeff: ah, that is the difference. A friend has a 2015 V6; he will bring the spare by the shop and we shall see if it fits.
Old 01-23-2023, 11:01 AM
Stan65 Stan65 is offline
I used a spare wheel/tire from this company. Clears my brakes just fine.
https://modernspare.com/product/2014...e-kit-options/
Interested in the brake setup you are using….
Old 01-23-2023, 12:03 PM
The base model G8 that had the V6 engine came with a spare tire and jack kit. The GT and GXP models did NOT come with a spare tire or jack kit. Instead they came with a 12 volt air compressor and a can of tire puncture sealant.
When I took delivery of my 2009 G8 GT in 2009 I talked to a engineer at GM about the spare and we made arrangements to have the spare tire in the trunk of a base model G8 installed on a GT. It fit on both the front and rear. The only concern was using the spare on the rear with the limited slip axle. Note: The limited slip axle was not available on base model G8’s. So if you had a flat tire on the rear of your GT/GXP you may have to put the smaller diameter spare on the front and take the front tire and put it on the rear.
I then found out about a dealer who was selling jack kits for less than dealer cost. I figured the dealer must have been buying the kit directly from the supplier. So I ordered a kit from the dealer. I then ordered the steel space saver wheel from GM parts using my GM employee discount. The hard part was buying the actual space saver tire. It came from a supplier in China and there were none in the US and none on order. Eventually I talked to the right person at GM Parts and he said he had a few other calls about the tire and that he would place an order for 50.
