Old 02-12-2023, 08:11 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
Default Overloading Quadrajet
Last fall I began to have problems with fuel blowing out the carb. I assumed some dirt got into the works, so I took it apart and put in a new float, new gaskets and all the other parts that came in the kit. Placed the carb back on and within a moment it was doing it again. Several times in fact
I had already ordered a new Q-jet from SMI as the old one had formerly been on an old combination (455) (now a 467 Stroker) that has a flat spot in it that I couldn't seem too tune out.
Put the car away in the fall, and last week the new SMI carb came in. I uncovered the car today , hooked up the new carb and 30 seconds later gas was puking. Same issue.
So now I suspect the fuel pump. It is an Edlebrock mechanical 110G unit that has been on the car for 15 years. it only has a main line in and a line to the carb. No return line
I'm assuming the pump is putting out too much pressure but don't have a pressure gauge in the system to check it. I was wondering why all of a sudden, the pump would up the line pressure after performing flawlessly for years.
Before I toss it out I thought maybe some of you guys could help with a adding a new pump (no I don't want to go electric) . I was looking at a Carter from Rock Auto, but they are only 40G/Per minute
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 02-12-2023, 10:20 PM
https://www.summitracing.com/search/...20-gph-454-lph
it does look like the 110G type pumps are still available if you'd like to get the same of what you already have. you may want to put an inline fuel presure gauge to validate what's going on.
2007 Grand Prix GXP 5.3L
Old 02-12-2023, 10:32 PM
Vroom_vroom's Avatar
Vroom_vroom Vroom_vroom is offline
The eddy pumps can be rebuilt.
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember
Old 02-12-2023, 10:37 PM
tom s tom s is online now
might give Sean a call as he built your carb?He will probably suggest putting a fuel pressure gauge inline to see how much its putting out.Tom
Old 02-13-2023, 05:59 AM
Kenth's Avatar
Kenth Kenth is offline
Check for proper installation of float needle pull clip.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-13-2023, 09:21 AM
Reversion, or a float-seat problem?
Reversion needs the fix to occur at the exhaust system config, cam overlap and intake manifold.
Old 02-13-2023, 10:57 PM
02Hawk's Avatar
Tried a 3rd carb tonight ....It did the same thing, blowing gas out of the bowl...so it must be the mechanical pump...ordered a new one and will take this one off and get it checked out
The Following User Says Thank You to 02Hawk For This Useful Post:
Old 02-14-2023, 02:40 AM
wakesupremo wakesupremo is offline
Inline regulator?
The Following User Says Thank You to wakesupremo For This Useful Post:
Old 02-14-2023, 11:33 AM
should not need a regulator with a stock fuel pump.I run the Carter street pump without one with no issues.Tom
Old 02-14-2023, 12:33 PM
25stevem's Avatar
25stevem 25stevem is offline
Really, reversion you say?!
Would that not be making for a backfire condition?
I do stuff for reasons.
Old 02-14-2023, 02:44 PM
Originally Posted by 25stevem View Post
Really, reversion you say?! Would that not be making for a backfire condition?
Backfire more likely from a rotor-post mis-alignment, or wiped Exhaust lobe.
Strong reversion under off-idle rhomp is more like a Sneeze, which is usually revealed by a lean-out condition. I think.
Old 02-22-2023, 05:58 PM
NeighborsComplaint's Avatar
Check fuel pressure with an inline gauge. Many of the Edelbrock pumps are known to put out 8 -10 psi and overpower the needle and seat. Some of this has been posted here in this board. If the fuel pressure is that high, install a pressure regulator (Holley has an inexpensive unit) and set to 5-6 PSI delivery.
Triple Black 1971 GTO
Old 02-22-2023, 06:06 PM
^^^ this exact problem and solution.
