Old 02-17-2023, 05:58 PM
SD455DJ SD455DJ is offline
Originally Posted by 79 Phoenix View Post
Thanks for the info guys! I rechecked the ad and the the description of the KS wheels is 14 X 7! Thanks for catching that for me! Thanks too for all the other helpful info on these wheels.
I'm thinking I would like the look of the 15 X 7 rather than the 14 X 7. Plus more tire availability for the 15" rims.
Also, are HM and HW the same in appearance? Are all the 15 X 7 the same back spacing?
These are HM 15x7's on my Lemans.
Dennis
Name:	70 Lemans Factory M-20 4-spd.jpg
ID:	607344   Click image for larger version
Old 02-17-2023, 07:44 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Dennis
They look good! Thanks, that's very helpful.
Old 02-27-2023, 05:52 PM
79 Phoenix's Avatar
On a manual drum brake car is there just a distribution block and not a proportioning valve?
Old 02-18-2023, 01:42 PM
79 Phoenix's Avatar
Dennis
What size tires?
Old 02-18-2023, 03:53 PM
What size tires?
225/70R15's (27.07" tall)
Old 03-01-2023, 02:38 PM
79 Phoenix's Avatar
I found this on top of the gas tank! It's still mostly readable. Anyone know how I can decipher the codes?
Also, On the rear end housing, these brake line clips are probably going to brake off when I try to use them again because they are sooo rusty... Is there a solution other than welding on new clips?
Name:	Build Sheet 1.jpg
ID:	608168   Click image for larger version
Name:	Brake line clip.jpg
ID:	608169   Click image for larger version
Name:	My work space.jpg
Old 03-01-2023, 03:18 PM
Congrats on the buildsheet find!
I'm sure you'll get a decode of it, but a quick glance from me shows WR engine code which is 350 2bbl and 3.23 gear ratio.
Old 03-01-2023, 04:42 PM
Great luck on finding the Buildsheet !
You won't need to buy a PHS Invoice for the car.
Sold new to dealer
08-371 Weidner Pontiac Co. 760 Park Ave. Mansfield, OH 44906
You can decipher the codes with some good reading glasses.
In row #40 you have item #1
Row #43 you have items #2 and #4 (6)
Row #47 you have item #4
etc .....
Its upside down and gets blurry when I try to magnify it.
Axle code WF is 3.23 single-trac/peg-leg
Carb code JE will be stamped onto carb where the part number and date code are stamped - if it is still original carb.
Old 03-01-2023, 05:58 PM
79 Phoenix's Avatar
Attachment 608182Attachment 608180
Sold new to dealer
etc .....
Thanks! I didn't realize it was upside down... Here's a right side up picture and bigger too. I was told it was bought new in Mansfield, OH... The original owner sold it to the guy I bought it from who sold it to me because he hadn't touched it in 4 years. So I will be the second driver. I was hoping for 3.55 gears but the 3.23's will suffice.
Name:	COMPLETE BUILD SHEET.jpg
Old 03-17-2023, 03:42 PM
79 Phoenix's Avatar
Default Door Panel Question
Well, I have gotten nothing done this week. Out of town 2 days and sick the rest!
But I did sell my driver's door that was beyond my capability to fix. In removing the door panel, it is apparent that the vinyl surface is actually in good shape. The cardboard behind is warped. It doesn't show much in the picture but does show when it's mounted on the door. QUESTIONS:
1) Is there a way to flatten the cardboard back out?
2) If I re-mounted the vinyl on a flat cardboard, would cardboard from another A Body door panel work? , Which models and years would have the same cardboard as the Pontiac? I know where there are some Olds Cutlass and Chevelles...Maybe a Skylark...
I'm going to stick the new door (purple)on temporarily and then get back to work underneath the car.
Name:	NEW DRIVER DOOR.jpg
ID:	609001   Click image for larger version
ID:	609000   Click image for larger version
Old 03-01-2023, 05:34 PM
79 Phoenix's Avatar
Thanks John. I knew it had the 2 bbl 350 but was hoping for 3.55 gears... 3.23 not too bad though. My 79 Phoenix came from factory with 2.42 gears!
Also thanks for the gear ratio/tire size/RPM calculator you put out there. It has been helpful to me and many others over the years!
The Following User Says Thank You to 79 Phoenix For This Useful Post:
Old 03-11-2023, 07:19 PM
400 Lemans's Avatar
Hard to read but the one at the top is your cam, i believe.
Name:	crane cam (1).jpg
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 03-12-2023, 03:37 PM
79 Phoenix's Avatar
I appreciate you looking at this.. Yes, I think you are right. I wonder if it's even as much cam as original?
Anyway, the way the exhaust sounded when I listened to the video of it running before he removed it from his car bears this out. Very smooth and definitely no lope at all.
It's all okay though because my objective isn't performance. If it was I would probably spend several more thousand building a 400 or 455. The more I think about it, I will probably just leave it as is. Maybe even remove the 4 bbl and use my 2 bbl manifold with rebuilt carb. A new cam might mean different push rods and possibly valve springs... I just don't want to put a lot of money into a ho-humm engine when I already have one that, though not powerful, runs decent... Similar to how the original once did.
Old 05-03-2023, 04:56 PM
79 Phoenix's Avatar
Came across some great deals on parts I will definitely need this past week.
Both my front fenders are rusted beyond my ability to fix...fender and bracket rusted away. Also, there is evident bondo in both current fenders. Passenger is also bowed out somewhat. So, instead of getting patch panels I was able to get these fenders that I can fix myself. Brackets are solid and fenders are straight and otherwise in pretty nice shape.
I also was fortunate to get and exceptional set of 15 X 7 HW code Rally II wheels that came off a 77 Can Am... Super clean and a great deal!
BTW, if anyone is looking for a nice set of 15 X 7 HW or HM Rally IIs, priced reasonably,, he has another set in excellent shape. Let me know and I will get you contact info. Wheels are in NJ.
Tomorrow back to working on underneath the rear.
ID:	611884   Click image for larger version
Old 03-11-2023, 03:01 PM
79 Phoenix's Avatar
This cam was installed after the original factory cam lost a lobe because valves adjusted too tight...at least on one cylinder.
So the guy I bought it from put this cam in with new lifters, pushrods and valve springs (and 4 bbl) as a repair to get the car back on the road. I'm guessing, because this cam was available not necessarily for performance. His plan was to build a 400 anyway, so he just wanted to get this one running well.
I'm not looking for high performance from this 350 but would like it to run maybe a little better than stock. It has # 94 heads and a 625 cfm 4bbl carb. I'm thinking a cam that would give a slight boost in low to mid -range torque. Any suggestions or thoughts?
Old 04-30-2023, 08:45 PM
79 Phoenix's Avatar
Default 77 Can Am Wheels
Question: Should 15 X 7 wheels off a 77 Can Am have 4 3/4" bolt pattern?
Old 05-01-2023, 12:04 PM
Yes , they would.
And Can Am had White & Silver paint scheme on their R2 wheels.
Old 05-01-2023, 12:25 PM
79 Phoenix's Avatar
Yes , they would.
Great. Thanks for the info!
Old 08-27-2023, 04:55 PM
79 Phoenix's Avatar
Continuing progress... Finished fixing rear quarter behind back tire. Started getting front end apart... It's further apart than pictures show. Still needs removal of bumper and core support. I have discovered core support is completely rotted out at frame mount...Hopefully I can get it repaired... The front body is complicated!! lots of parts!
Name:	driver side qtr.jpg
ID:	618946   Click image for larger version
Name:	rear qtr 1.jpg
ID:	618947   Click image for larger version
