Old 02-27-2023, 02:53 PM
Ken, you are crushing this! May the karma gods be shining on you and your round port heads.
The Following User Says Thank You to will slow gto For This Useful Post:
  #122
Old 02-27-2023, 03:06 PM
dataway's Avatar
dataway dataway is offline
Got my decals ... Love Them
  #123
Old 02-28-2023, 03:27 AM
Verdoro 68's Avatar
Ok Dennis, here's a pass at the 455 HO emissions label. This one is deceptive - seems simple, but there's a bunch of details to capture...and I keep finding them when I think I have it. Fonts could use a little more massaging in some places. I'm guessing they moved on from water slides to stickers at this point?
And a pass at the controversial and elusive '69 emissions decal. Without an original, I assume it would be based on the '68 style but I don't really have enough to go on. I won't produce this one unless someone comes up with an original. Reading through old threads, it may have even been paper.
ID:	608075   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
  #124
Old 02-28-2023, 12:48 PM
Shiny Shiny is offline
Wow, that's so good!
The use of all the "periods" for abbreviations and incomplete sentences caught my eye. I view it as part of the history and nostalgia - the transition to digital everything. As we all started typing, adding punctuation became a nuisance and the styles changed.
  #125
Old 02-28-2023, 01:28 PM
Verdoro 68's Avatar
Thank you! All the details add up. I do my best to capture all the oddities in spacing and characters even if it's funky. For example, the @ signs and parenthesis are different fonts and the spacing between letters and words is generally pretty inconsistent and tailored to match the original. Reproducing the illustrations can also be really time consuming.
And...I just noticed a typo on step 6 in the mockup above so here's a new one. I'm not sure the type is exactly right for the steps. Looks a little heavier in the original, but I'll see how it outputs.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #126
Old 02-28-2023, 02:01 PM
SD455DJ SD455DJ is offline
Ken, I just saw this...frickin' nice! Excellent work! This is sooo much better than the other decals out there. My comments are the fonts need a little massaging, like you said earlier, and the timing should be 12 degrees instead of 10. The line work looks a little too light, too. So sorry if I'm being to fussy.
It is a decal, not a water transfer, but seems to have a clear vinyl protective cover, or coating (?) on it...maybe?
Thanks for your fantastic work!
Dennis
  #127
Old 02-28-2023, 02:09 PM
Verdoro 68's Avatar
No worries, lets get it right! I'll keep messing with the line work trying to find a good compromise on weight. I had it heavier, but it looked TOO heavy based on the pics. Please feel free to keep proofreading as well. I fixed the timing - not sure where the 10 degrees came from considering I drew the illustration with 12!
I think the way I had the '68 emissions stickers done with the glossy UV protective coating would work well for these.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #128
Old 02-28-2023, 02:19 PM
Ken, I also agree with you on the '69 350,400, 428 4-bbl emissions decal to not be completed until we find an original.
Dennis
  #129
Old 02-28-2023, 03:37 PM
Just for reference, here's Dan's '69 350HO Firebird's original air cleaner (PV code 6485501) with the HD filter option.
Dennis
Name:	'69 Firebird 350HO HD Air Cleaner.jpg
ID:	608098   Click image for larger version
Name:	'69 Firebird 350HO PV Air Cleaner.jpg
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
  #130
Old 02-28-2023, 03:42 PM
Thanks for working on these Ken!
Will be in for half dozen '71 455 HO emission decals. Several '69 emission decals as well.
  #131
Old 02-28-2023, 06:53 PM
Verdoro 68's Avatar
If anyone has a high res photo of a 455 HO decal drop me a line. I'm having trouble figuring out the finer details of that one via the low res pics in the forum.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #132
Old 03-01-2023, 02:19 AM
Verdoro 68's Avatar
Took a pass at refining the 455 HO label. As far as I can tell, some of the lines breaking up the info are thicker than others. I was bouncing between a couple different fonts for the tuning instructions, and I think I got it as close as I can. If someone has an original to compare to, happy to email a higher res version to print out. I also need a size for this label.
ID:	608140   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #133
Old 03-01-2023, 04:59 AM
Held for Ransom's Avatar
Crude dimensions are here...
https://forums.maxperformanceinc.com...d.php?t=472074
So long, farewell.
  #134
Old 03-01-2023, 12:21 PM
Verdoro 68's Avatar
Looks like I'm not the first person to go down this path! The pics in that thread are helpful, thanks. It appears my assumption about the line weight in the decal was wrong. I can tackle the '72 decal once I get this one nailed.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #135
Old 03-01-2023, 01:14 PM
Ken, PM me your email address and I can send the larger jpg file to you...if you need it still...
Dennis
  #136
Old 03-01-2023, 02:10 PM
pggto's Avatar
pggto pggto is offline
I have one still on my car, if you would like a better picture I can get one next week sometime. It's not perfect but it might be good enough for some info.
Just curious, have you tried a hand held inkjet printer to see how it compares to the silk screen? I work for a company that makes labels and signs and we had one here in the shop for a project a while back. It will print jpegs if I'm not mistaken. I'll have to see where that printer ended up. I know I was playing with it and it would do color company logos.
Name:	71 455 HO Decal.jpg
  #137
Old 03-01-2023, 06:23 PM
Verdoro 68's Avatar
Dennis sent me one, thanks. My last rev was close, but not spot on. Found some differences in font shapes and such which I'm correcting by hand.
Interesting, I've never heard of this. I'm keen to replicate the method the factory did which is why I went down the silkscreen path. It's also something that anyone could apply.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #138
Old 03-01-2023, 09:38 PM
Really looking good Ken!
Dennis
  #139
Old 03-02-2023, 02:30 AM
Verdoro 68's Avatar
Got into the weeds on this one tonight. Thanks to Dennis for sending me a high res pic to work off of, it helped quite a bit. I ended up redrawing it at 4x the actual size to capture all the details and shrinking it down.
It turns out I had the wrong style periods (square vs. round) and I had to make a number of characters to match whatever the original font was. With the lower res pics, I was having a hard time figuring out what font weight the instruction list was. Much easier when I have a giant pic to work from. I had them too light in the previous iteration.
I was also able to tweak the illustrations so they had a heavier line weight and matched the original exactly.
Here's some of the process....
Draw on top of the pic of the original. It had a slight skew to it, but no big deal.
Convert everything to outlines so I can tweak the fonts and get the inconsistent spacing down.
Looking closely at the original, the fonts weren't super crisp. I could print them that way if folks prefer, but I also applied a slight rounding to all the fonts to mimic the sloppy original.
Digital fonts are crisp and clean:
Apply rounding to mimic the factory quality:
The end result. Still needs a little bit of tweaking to fix up the letter spacing and some of my custom letters in some spots, but it's way closer than what I had and keeps some of that wonky factory charm.
ID:	608199   Click image for larger version
ID:	608200   Click image for larger version
ID:	608205   Click image for larger version
ID:	608206   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #140
Old 03-02-2023, 03:49 AM
dataway's Avatar
I like the more rounded font ... but it's got to be pain to individually alter each letter. Hopefully you have some kind of font tool you use to do them en masse.
