Eric I have had real good luck with the DUI HEIs.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Funny you should mention DUI ignition. The Supercharged Studebaker I posted about in another thread was on the dyno just before Eric's Pontiac. The Studebaker was a special GM DUI HEI grafted on to a Studebaker base. It worked fine until they turned up the boost on that engine. When they increased the boost above 8 PSI, they began to have some misfire and ignition issues. We decreased the plug gap to about .022" and it ran better but not as well as a point ignition Studebaker distributor they had as a back up triggering an MSD 6 with Blaster coil. Just don't think HEI has enough spark energy for boosted or high RPM operation. I could certainly be wrong, but the last two engines on the dyno have had HEI issues. Don't know the history of the Studebaker DUI, how old or how many miles on it.
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
