#301
Aftermarket Tomahawk valley plan.
I had thought about notching the washers because it's less visible. Let me see how much needs to come off and make a call.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
#302
The last one I did I used a round stone on a drill, that had a flat face. It was just slightly larger than the washer. I walked it back & forth over the edge, if you can imagine that.
I know OE valley pans need doctoring, will have to look and see if my Tomahawk was doctored or not. Some reason I'm thinking no, but it's been a while. .
#303
my Tomahawk needed massaging in some of the corners.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
#304
I needed to remove about .10 from the crossover, so I busted out the trusty Dewalt cordless die grinder with a carbide bit. I picked this tool up to port the intake and it's come in handy so many times including clearance the block. Multi-speed trigger with a switch to toggle between three max RPMs. Highly recommended and everything sits nice and level now.
Other than the intake ports, I'm not seeing any other place the valley pan needs some massaging. When the pushrods get here, I think I'll be good to button this thing up. There's a machine shop with a Superflow dyno down the road. Thinking about seeing what it puts out before I drop it in the car.
| The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#305
New pushrods received. They fit like a glove. Adjusted the valves and primed the engine while rotating the crank. I saw plenty of oil getting around so my son and I proceeded to put the distributor, valley pan and intake on. I got to teach him about the firing order and how a distributor works and had him wire up the plugs. I tried to get the timing as close to start up advance when I put the distributor in. We'll see how good I am.
It sure looks good on the stand all shiny and dressed up. Reminds me of the scene from Spinal Tap with the guitar on the stand that's never been played. Nigel Tufnel: The sustain, listen to it. Marty DiBergi:I don't hear anything. Nigel Tufnel: Well you would though, if it were playing. The local shop with the Superflow only dynos their own builds. Called around and couldn't find a dyno that was within a distance I wanted to travel, so I made the executive decision to drop it in this weekend. Maybe I'll circle back with a chassis dyno after we get it installed. Wish us luck!
| The Following 5 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#306
Nearly 12 hours of wrenching and it's just about ready to put fluids in and fire up.
I didn't check that the converter was fully seated which prevented the first attempt at placing the engine. Once I got that solved, the Ames motor mounts fought me for a little bit. Nothing a little pry bar couldn't fix. Looks good.
#307
Great work. Looks amazing.
#308
Beautiful. Almost to that magic/scary moment when it comes alive.
#309
Fired it up this afternoon! It was probably the most smooth new engine fire up I've had, knock on wood. Basically turned the key and off it went.
Broke it in according to Butler's instructions. Oil pressure looks good, temps stayed low, vacuum is steady. Minimal leaks to contend with.- just a small fuel leak at the carb and a power steering overflow. Hopefully it stays this trouble free! A little bit of sewing machine noise from the lifters at idle, but not too bad. Idle is pretty mellow and smooth thanks to the 114. The gen light stays lit all the time, even when the car is off. That's new. Could be the new engine harness or the new Powermaster mini starter. If that's my biggest issue, I'm ok with that! Throttle blip in driveway left a couple of patches. If that's any indication, this is going to be a fun engine. Video: https://youtu.be/hyZMm12bzYg
#310
Looks and sounds fantastic! What lifters do you have? They don't sound too loud in the video.
#311
Johnson lifters. They're really not bad at all, I only hear them at idle. I'm pleasantly surprised by how easy this thing fired off! I haven't drained the break in oil yet so I hope I'm not jinxing myself.
#312
Correction, mine are the "reduced" travel, .093.
#313
These are the regular ones. I can also check my preload. I went pretty conservative on them erring towards 1/8 turn.
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#314
Agreed! I’d be very happy with that sound.
#315
What did Butler recommend for break in?
#316
I looked at both Butler and Comp roller break in instructions, as well as some others, and they were pretty much the same as a flat tappet so I kept with that.
Initial fire up instructions: https://butlerperformance.com/file/3...+Procedure.pdf Cam break in: https://butlerperformance.com/file/1...t+Break+In.bin
#317
Before you take it out again, be sure to wipe my drool off of the pics you posted, haha. Beautiful and congrats on the smooth fire up! It’s nice when things go right huh?!
![]() ![]() Sent from my iPhone using Tapatalk |
#318
It all looks Born-With
Great Work ! What is your rear gear ratio ? |
| The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
#319
That’s the idea! Rear end is a ‘69 XH 3.55 posi. We’ll see if it lasts!
#320
Drained the oil from break in last night. There was negligible bit of sediment on the drain plug which was nice to see. I did see some flecks when I drained the oil filter. Nothing uncommon for a new build but I'm glad I changed the oil immediately. Per Butler's instructions I put a fresh batch of Driven BR 15/50 in.
It's very angry on a cold start, but once it warms up a bit it idles smoothly and stays cool with the 160 degree thermostat. Oil pressure is where it should be. Looks like it's around 70psi which is perfect considering I added the shim in the oil pump for a little more pressure. Props to Ray Klemm for the awesome job on the carb. Only minor adjustments to idle speed needed! The new trans was thirsty. I think I ended up putting in about 11 quarts or so. It may want more when I'm able to take it out for a drive. I accidentally debugged the perpetual GEN light as well. I was on the phone with M&H for a while and we were both perplexed. I noticed I was getting power to two wires at the voltage regulator when the car was off. I went to remove the bulkhead to check for power and continuity and noticed the offending wire lost power when I backed the bolt out of the bulkhead a few turns. Problem solved! I still need to get the underside of the hood prepped and painted, the rain has been preventing that. After that, it needs an alignment and the A/C reinstalled and charged. My son is already bugging me to take to open shop night at his school.
| The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
