Quick question, anyone running caltracs can you please give me measurement on rear mount - bar bolt hole distance from flat part of plate. Basically how far down is rear hole
Thanks Eric |
i have a set of moroso slide a links i can measure if that would help
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
Sure thanks
I can measure mine
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
On mine the centerline of the hole is about 3-1/4" to the bottom of the plate.
My set are quite old. https://calvertracing.com/product/mt-2-mount/ Information on line states the distance should be enough so that the rod should be able to miss the springs by at least 1". If it doesn't, these lower brackets will need to be a little longer. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 03-19-2023 at 03:12 PM. |
Thanks for info
