Old 03-27-2023, 12:52 AM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Default 1969 Custom S 4 door sedan at DVAP
Just found this online, Desert Vally Auto Parts, same basic car.
https://www.dvap.com/project_car/196...dan-69po7847b/
The Custom S has been getting prepped this past week for painting sometime next week. The windshield and rear window were removed and minor rust was found at the windshield base that needed some metal work. Fortunately, the rear window channel needed only a little tweaking otherwise was in great shape. The rear window’s seal had a breach at the bottom channel and would let water in the trunk, but, fortunately the car led a garaged life, so no damage (rust) in the trunk. The entire interior is now out, save for the dash and steering wheel, so this is getting pretty serious for a ‘scuff and shoot’! The front fenders were removed and the back sides and inner fender wells were covered with something like ‘cosmoline’ that is practically impossible to remove, so more work needs to be done to get them ready. The original carpet (tags are still on the underside) got a first cleaning along with the original seatbelts. The front bench seat base is pretty ripped and worn (hence the seat cover) and we’re going to take it to the upholsterers to see if they can match the vinyl grain and pleat pattern. The seat back looks to be in nice condition.
Dennis
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 03-27-2023, 07:47 AM
SD455DJ SD455DJ is online now
It sure is! I wonder what they want for that one and what the option list is...? Could it be another 350HO Custom S?
Dennis
Old 03-27-2023, 02:23 PM
New to stock, Call DVAP quickly to save this car
1969 Pontiac Lemans “Custom S“ 4 Door Sedan
**For Viewing Only**
New to stock and we are still waiting on paper work, so this car is posted to “view only”. Price has not yet been set. Call with questions.
Dennis
Old 03-30-2023, 08:34 PM
Dan replaced the driver side motor mount which required the removal of the starter to make it easier to do. The old mount was crushed allowing the engine to lean down so much that the exhaust manifold almost hit the crossmember. We discovered the Custom S has its original 1107355 starter dated 8-L-1 (Nov. 1, 1968) as well as its original torque convertor with the '55' paint stencil. He also replaced the original heater core that had been solder repaired and had a slow leak in the core at a previous fix. Rear window, bumper and tail lights back on...a new tinted windshield had to replace the original non-tint that had a stone chip that spread all the way across when it was removed...bummer. Interesting to know that the 4-dr windshield is 1" taller than the 2-dr windshield. Making progress...
Dennis
ID:	609972   Click image for larger version
ID:	609973   Click image for larger version
ID:	609974   Click image for larger version
