#261
Thanks for the pics. Paul
#262
Dennis |
#264
Thanks for the information.
#265
There was also no sprint option on wagons in 69, unlike the lack of dual exhaust option on wagons in relation to the 350 HO there was no technical reason for the lack of Sprint on the wagon so must have been just insufficient demand. That means only the 1bbl 250 and the 2bbl 350 were offered on 69 A body wagons. Similarly the 428 HO was not offered on full sized wagons in 69, probably because it would have required specific wagon only larger diameter tailpipes and resonators.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
#266
The Custom S is almost whole again. Front sheet metal is now installed along with the bumper and grilles. Just needing final alignment tweaks, the front valance and some minor chrome installed and it's drivable again...well, waiting on the front bench seat at the upholsterers too...kinda need that to drive.
Dennis |
| The Following 2 Users Say Thank You to SD455DJ For This Useful Post: | ||
#267
Stunning.
Never thought I’d be into a 4-door but this one’s a game changer. ![]() I’ve always liked the Plain Jane cars, better yet an original 350 HO sleeper.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
#268
Dennis, who needs a seat......that's what those milk crates in every shop are for.
Looking good! It is a COOL car indeed, but I can vision an IA2 block with big cubes under those heads and intake. Painted Pontiac metallic blue of course! |
| The Following User Says Thank You to JSuchma For This Useful Post: | ||
#269
Dennis |
#270
Dennis |
#271
I frequent a lot of body shops in my business. Every one of them has at least one milk crate laying around.
#272
So is the 8 track player going back in?
#273
Stuart, Well...? We took it and all the wiring out for now (power & ground is all), but it's pretty easy to reinstall if we get the bug to do so later. I would like to think we will once I go through the 8-track and make it work a bit better. Probably needs a good cleaning. It is an odd period piece and part of the cars history.
Dennis |
#274
The rubber drive belt inside the 8 track is probably toast, but there are places that sell replacements.
(My first job out of engineering school was at a company that built magnetic tape heads. I was there in the late 1970s so 8 tracks had gone by the wayside and they had moved on to computer disk drives, but their tape heads had been used in most GM factory tape decks in the early 1970s and we still had plenty of parts laying around in the lab.) |
#275
Stuart, when I get it apart, I'll post some pictures to get your advice. I'm sure the former owner (wife) will wonder why it isn't there (in the car that is).
Dennis |
#276
We got the front valance on with the turn signals and side marker lights today, so that wraps up the body side of the equation. Now we just have to get the front seat back from the upholsterer! We have to check for a bad ground as the driver turn signal doesn't light the running light filament of the bulb (tried several new bulbs...same result every time), and the signal and hazard lights flash dimly, but at the normal pace. The passenger side turn signal works great in all modes.
Dennis |
#277
I recall that the 69 Twmpest-LeMans wiring harness is different than the GTO due to the grounding for the parking lights. I believe the goat lamps have a ground wire in the socket but not the Tempest-LeMans which uses the parking lamp ground comes from the metal lamp bracket.
If the valance is painted heavily it might not be grounded to the body.
#278
Thanks North! I recall 3-wires to the connector socket, one being a small round hole in between the two larger spade receivers. We were thinking that's a ground wire in the socket...?
Dennis |
#279
That is a strikingly beautiful car. Thanks for sharing the effort and results.
The front bumper and grill are amazing tributes to the era for me. Is that original chrome? Wow. Mike |
#280
Thanks Mike! We appreciate it. Yes, the chrome is original and looks presentable, but is old and you can see hazing when you look at it closely but is perfect for the condition the car is in...for a driver.
Dennis |
