Old 04-19-2023, 10:30 PM
Tim Corcoran's Avatar
Default 67 A-Body with X Pipe
Dows anyone have pictures of a dual exhaust system a 67 Tempest/LeMans or GTO that they could post? With an X pipe even better. Thanks
After market of factory either one preferably both
Tim Corcoran
Old 04-19-2023, 11:48 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Do any of these help? If you scroll down to the install galleries tab they have 4 installs on ‘67’s (2 on frames minus bodies). I usually use them for install pics or Gardner for OE type install pics.
https://www.pypesexhaust.com/product...-409-stainless
Sorry they won’t allow me to direct link to the galleries.
Old 04-20-2023, 01:10 AM
ZeGermanHam's Avatar
Here is my '66, which is going to be the same as a '67. I used the Flowmaster 2.5" mandrel bent kit with Dynomax Super Turbo mufflers.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 04-22-2023, 11:16 PM
leeklm's Avatar
leeklm leeklm is offline
Used that same kit with super turbo on friends 66 gto, and used the Flowmaster 3" kit with qtr exit and ultra flow mufflers on my firebird. The flowmaster pipe kit works well IMO.
Sent from my SM-G965U using Tapatalk
Old 04-24-2023, 06:38 AM
Thanks for sending the photos, one of my concerns is if I use Walker 17749 Super Turbo Mufflers, they are 20" long will they fit up in the rear so everything tucks up nice.
Tim Corcoran
Old 04-24-2023, 07:40 AM
The Champ's Avatar
Mine is a '64, but should effectively be the same as your car. I have the 17749 ST's and an X pipe.
Hope this helps.
ID:	611330   Click image for larger version
Old 04-25-2023, 11:51 PM
Champ, how do you like the sound with the X pipes? Any drone?
Tim Corcoran
Old 04-26-2023, 07:45 AM
The Champ's Avatar
No drone at all. Some would prefer a louder muffler, but with a convertible where the top is down 90% of the time, I don't want excessive noise.
Having said that, I have had a jacked up Ram hemi pull alongside at a stop light and comment that I must have some cam in that GTO...
Old 04-26-2023, 07:46 AM
The Champ's Avatar
Old 04-30-2023, 10:56 AM
I currently have Dynomax 17749 Super Turbo mufflers on my 67 LeMans with 2-1/2 dual exhaust and I do have some drone at certain speeds. The guy that did the exhaust years ago did a crappy job and has the mufflers way forward and everything hangs down and looks stupid as you can see the exhaust hanging down when viewing the car from the side. I plan to re-do the system and go with either an H-pipe or X-pipe to remove the drone. I'm curious if I would like to the sound of the H-pipe or X-pipe better and which one does a better job of removing the drone. Any thoughts?
Tim Corcoran
Old 05-19-2023, 05:04 PM
Champ
Did you use the Pypes pre bent system? Did you have a problem getting the pipes tucked up so you don't see the pipes hanging down? Did you modify the down pipes to get better ground clearance? Thanks
Tim Corcoran
