Old 04-27-2023, 12:37 PM
P@blo's Avatar
P@blo P@blo is offline
Just an FYI for those reading, the weight of a link bar setup shouldn't even be a player in the grand scheme of things so long as the rest of the valvetrain is setup properly (IE: correct spring pressures) And with these low revving Pontiacs that people are typically building in here, it's really a non issue.
And another FYI for those reading. Shouldn’t or won’t? Posts keep popping up that might suggest shouldn’t.
I know, grease the wheels but there seems to be no magic retrofit bullet. And then the added cost…
Old 04-27-2023, 01:17 PM
Won't
Most guys here don't even spin their Pontiacs above 5500, and many others don't make power much above that. It's the street section. With a proper spring valve train control is not an issue with these things.
If you want to save weight on the valvetrain then look at retainers and valves and don't worry about link bars.
https://youtu.be/XqEydRRRwqE
Old 08-21-2023, 05:15 PM
Stan65 Stan65 is offline
Singleton,
For the guy that wants to keep the "EGR" valley pan, there are no other hydraulic roller choices I am aware of. It would definitely be for the "mild" build setup.
It's just a spit ball idea. Not in it to make a business. It's just a hobby and I like a challenge.
Here's to the "you can't fit a finned aluminum timing cover under the water pump on a 409" so I made my own. It was marketed for a few years by a buddy until he retired. I have the knowledge and ability, and he had the CNC mill.
Thanks,
Stan
ID:	618565   Click image for larger version
ID:	618566   Click image for larger version
ID:	618567   Click image for larger version
ID:	618568   Click image for larger version
The Following 2 Users Say Thank You to Stan65 For This Useful Post:
Old 08-21-2023, 05:18 PM
Any reason why you want to keep an EGR valley pan?
Just thinking out loud but it seems it would be easier and much cheaper to just modify the EGR pan to work with retro lifters rather than reinvent the wheel trying to design a lifter to fit the pan.
There has to be a way to make the pan fit with a little time spent....??? If it were me I'd ditch it for a regular valley pan anyway.
Old 08-21-2023, 11:54 PM
Originally Posted by Stan65 View Post
Singleton,
Thanks,
Stan
Nice cover!
Old 02-11-2024, 11:24 AM
I’m still working that out for options, but the fallback will be the modified ford spider.
Old 02-11-2024, 12:11 PM
So what's the max lift this thing will support?
That's really the deal breaker for me and why I had to ditch the idea of using the factory roller setup on a Gen V BBC and convert it to link bar, it was all finished at .350 lobe lift which meant I couldn't even get a cam in there with more than .600" lift at the valve and that wasn't going to get the job done.
Old 02-11-2024, 01:07 PM
I don't have the answer, but from another thread from someone that is using them, "To use the HT2148 lifters, cam base circle must be at least 1.135” diameter".
If that is the case, anything less than 1.135" base circle would allow the lifter oil feed hole/band to drop out of the bottom of the lifter bore.
Lifter oil feed hole protruding out of the lifter bore at the top at full lift shouldn't be an issue unless the top of the lifter bore has an excessive chamfer from the factory.
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
The Following User Says Thank You to Singleton For This Useful Post:
Old 12-01-2024, 03:44 PM
ALL,
I just measured out everything in my setup so people can reference for their own purposes.
Once again, this is with MY BLOCK
You can see the lifters work well.
My cam measures....
Base Circle 1.191
Lobe Lift .344
Journal Diameter 1.899
This means my lobe is .010 under the journal radius as expected.
One caveat!......
THE OIL HOLE IN THE LIFTER NEEDS TO FACE THE OIL HOLE IN THE BOSS THE GET OILING ON THE BASE CIRCLE!
PM me if you want a copy of the DWG file.
Old 02-09-2024, 08:53 PM
gtospieg gtospieg is offline
cool...following
