Old 05-09-2023, 10:46 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
Originally Posted by Holeshot71 View Post
Do the valve cover bolt holes break through on any of the 4 intake ports? If they do did you put sealer in the bolts? I saw that mentioned earlier but didn’t see any response
I sealed those off with cut off studs when I first got the E heads. They never leaked and don't look like they are now.
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 05-09-2023, 11:03 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Maybe check and see if there’s oil on top of the studs? Also just noticed the PCV valve grommet you are using doesn’t look correct for the hole and may be leaking oil?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
