Old 05-09-2023, 07:17 PM
dbiggs dbiggs is offline
Default 66 GTO neutral safety switch
Swapped out ST300 for TH350. Does the stock neutral safety switch still work? Planning on getting the Ames 65-69 M156E
Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option.
Old 05-10-2023, 05:40 PM
The shift pattern is the same for park/neutral/reverse so give it a try. If it doesn't work then change it,
Old 05-11-2023, 12:24 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I did the same swap in my '67 Cutlass and everything worked without any big changes. (Took me 25 years to hook up the kickdown cable, though!)
Mike
Old 05-11-2023, 01:08 PM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
OE style switch works fine. We went to a 200-4R and utilized a ShiftWorks conversion kit.
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
