Old 05-11-2023, 09:44 PM
Gach's Avatar
Gach Gach is offline
I’d get the one from Nightmare, thing I like about is it has C-clip on it, so it can’t pull out of the pump if you need to pull distributor for any reason, or like to move it on tooth to get timing right. It is definitely the Harden one.
The Following User Says Thank You to Gach For This Useful Post:
Old 05-12-2023, 07:51 AM
chuckies76ta's Avatar
That and they have the sleeve over the pump end on the IA2 one I bought from them. And as mentioned, very good company to deal with.
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
