| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I have a receiver on my 2500 GMC. I lost(misplaced) my pin,for my hitch. So I went to local trailer dealer and bought a new one. I asked him how hard a pin is, just curious. He asked the manufacturer before but never got an answer. I get concerned about Chinese steel. I have special key locking pins but use a pin with a just a little spring pin. Wonder if the pin is just 1018 steel or could it be case hardened?
| The Following User Says Thank You to sdbob For This Useful Post: | ||
Bob, From E trailer: The typical shear strength of a 5/8" hitch pin is 90,000 LBS., or 45 tons. Even if it was inferior steel, and it was 40,000, or 20 tons, you'd be pretty safe. I've never seen many tow vehicles that can exert that much force on a trailer, it's pretty much a non issue. I've also never seen a hitch pin deform, or shear, probably not worth worrying about.
If you're still concerned, I'd buy a name brand pin, and it was likely still made in China............
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
The towing capacity of a motorhome is
rated by the manufacturer. Unless the frame is engineered and reinforced specifically to be utilized as a towing platform it is not suitable as a tow vehicle. Jim
Click Here To See Where I Am Today |
| The Following User Says Thank You to Trulyvintage For This Useful Post: | ||
But... When you purchase a motorhome and it comes with a Class III or higher rated hitch from the manufacturer it would appear that they have thought things out.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
They're have been many racers that have sheared off the rear frame of motorhomes towing an enclosed race car trailer with a bumper hitch. That flimsy, light duty rear frame section on most motor homes, is only meant to hold up the floor and living area. Flexing it over the road constantly, with 5 plus tons of trailer hooked to it, usually doesn't work out in the long term.
Maybe there is an option to use heavier steel for that section when it's being built, but any of the rear frames I've looked at are way to light duty for attaching a class 3 hitch to. BTW, maximum class 3 is only to 8000 Lbs, most open trailers with a car on it, and equipment carried on them will likely be over, or near that rating. E trailer does caution putting high weight rated hitches on motorhomes because of the frame deficiency of most motorhome rear frame sections. I've seen, and heard of too many racers breaking motorhome frames to think it's a good idea. |
My opinions are formed by firsthand
experience and advice offered by folks who are in vehicle enforcement including a recently retired Weigh master in California and active vehicle enforcement officers in Ohio - Oklahoma - Pennsylvania. My tow vehicle set up: 15K receiver hitch 15K ball mount or “ stinger “ 15K 2-5/16” trailer ball My current custom all aluminum trailer: 12K coupler 12K equalizer assist So my capacity is 12K for what I pull. Not a problem because I don’t transport any vehicles over 6K. If I added this bicycle carrier device my rating which decrease to 6K. That - is a fact. I am an actual business. I am subject to the law. I respect and observe and comply. Irregardless of my opinion of it. Jim
The manufacturer of this product
is in the business of selling bike and trike racks : @ https://www.hitchrider.com/ This appears to be a product someone designed to keep a bicycle rack they sell from ratting around ….. The manufacturer of this aftermarket product is not making an accurate statement in the email reply.. This is the legal description of a Class 3 receiver hitch according to Curt Aftermarket receiver hitches products are submitted for evaluation and review for suitably for application by the manufacturer to protect them from civil and criminal negligence claims arising out of claim of loss or failure. Sounds Ike this is a small company that chose not to do that - hope they have deep pockets in the event off a lawsuit. The manufacturer assigned a Class 3 rating to this product - if the manufacturer intended the product to be used on any class of 2 inch receiver hitch then that should be clearly stated in the description. Hitch Styles and Classes explained; @ http://forums.maxperformanceinc.com/...1&d=1690812264 Jim
Click Here To See Where I Am Today Last edited by Trulyvintage; 07-31-2023 at 10:26 AM. |
For the nerdy:
When the pin is holding the hitch together, is it one case of double shear, or two cases of single shear? Can see it both ways.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400 pontiac 72 4-4-2 Mondello's VO Twister II 1964 F-85 Home of the 700hp small-block Olds **Still wanting a 64 Bonneville or Catalina** |
double shear area of 5/8" pin = .613 in2 Assuming 1018 mild steel cold drawn, the ultimate tensile strength = 63,800 psi Shear strength is around 57% of ultimate so it's about 36,000 psi. So the pin should break at about 22,000 lbs. A wise traveler should have a safety factor of at least 2 or 3. So the allowable load would be 7000-11,000 lbs. Better pin material (like an alloy steel) would bump those numbers up a lot. Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
Looking further on some other sites I find specs of 21,000 lbs for 5/8 inch hitch pins. I've had to do some jacking on my 1900 built farm house and using a 20 ton hydraulic bottle jack, using a floor jack post, the adjustable pin started to deform the tubing before the pin sheared. From that example I'd surmise the mild steel would start to tear at the holes before the pin shears on a receiver hitch. Just an experiment I've run across in jacking my home up to where it was before everything sagged and settled in the last 123 years. The floor jack posts are rated at 18,000 lbs, much closer to Eric's calculations Bob, my apologies for citing the wrong information from E Trailer.com..... You'd think a business that specializes in trailer towing equipment would strive to have more accurate information on their website.Eric, thanks for some better calculations than E Trailer has posted....
You can get US made hitch pins at McMaster-Carr
| The Following 3 Users Say Thank You to 61-63 For This Useful Post: | ||
Thanks guys for the info. I get concerned about things as I age. When I was young teenager,I'm not sure how I made it to my 20s,then 30s etc
| The Following 2 Users Say Thank You to sdbob For This Useful Post: | ||
This is my 41st year of transporting with well over 4 million accident-free transport miles & I have NEVER bent or sheared a pin! I guess anything could happen, but there are many other things that go wrong more frequently while pulling the trailer.
The great thing about your concern is that should it ever happen, it would happen pulling away from a stop & the safety chains would keep the trailer attached to the truck, you would feel something right away & get out to check. No Harm, No Foul For piece of mind, you could carry a spare. God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society" Your QUALITY Pontiac Transporter Since '83 1955 Chevy Alt. W.B. Gasser 1955 Nash Ambassador Cust Lemans 1957 T-Bird 1964 Grand Prix 1966 Catalina Conv 1966 Ambassador DPL 2dr 1966 Ambassador Cust. 2 DR 1967 Marlin 1967 Toro 1973 Nova Chassis Car 1992 Jag XJS Conv 1992 Jag XJS Coupe 2007 Cad XLR-V Supercharged Roadster 2008 Avalanche Southern Comfort Edition |
I could almost see if the hitch was worn and the receiver was worn. That may cause some back n forth within the receiver itself and maybe could bend the pin. But if that is the case there is a lot more going on. I am with Bill. Although he has dreamt about pulling a trailer more miles than I ever will do so, I have pulled my share. The pin is about the last thing I would worry about. I bought one of those fancy chrome locking ones a few years ago when I was on vacation pulling my trailer. I was afraid someone would steal the hitch! Around home I just use a simple one from TSC. I have 2 trailers one is a pintle so I need to swap hitches on occasion.
| The Following 3 Users Say Thank You to TAKerry For This Useful Post: | ||
Receiver hitches wear out.
The steel receiver hitch tube and the solid steel stinger that your trailer ball mounts to are softer than the pin. The OP should have his receiver hitch and tow vehicle completely inspected at an established trailer repair shop and/or an established welder. My primary welder is in farm country outside of Iowa City, Iowa. All of my tow vehicles have been fitted with custom designed and reinforced receiver hitches by Reg Yoder at Sharon City Welding. One of several quality service providers who keep me going down the road …. Jim
You didn't mention what year your truck was, but some GM receivers were recalled for cracking. I believe the years were between 1999-2005.
After about 5000 miles of towing my travel trailer, I noticed the receiver tube was wearing out with the pin hole becoming elongated as mentioned by Truly Vintage above. Bought a new BW receiver for my 06 Silverado.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following 2 Users Say Thank You to OG68 For This Useful Post: | ||
I also have a couple of those locking chrome pins & had a thought in the back of my mind that maybe they were not as strong as the normal ones, but my minor concern was calmed by another million or so miles on each one! ![]() As for wear pieces....BOTH of the tongues on my trailers have over 1.5 million miles on each with little wear! Reason being, I lube my balls (insert joke here) before I leave the shop EVERY time! I was actually thinking of replacing them both along with the balls just for Sh1ts & Giggles this year. With my anal maintenance schedule, my trailers never leave the building with anything wrong. Fact is...I want to get my customers cars delivered on time & want to get back home to work on mine as quickly as humanly possible!!!!! God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
| The Following 2 Users Say Thank You to Bills Auto Works For This Useful Post: | ||
Very impressed...$9.95 shipping & it is already on its way! Hope the quality is as good as the customer service.
I will report back when I get the 1st one. God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
So - if you tow ….
It is a good idea to have your tow vehicle inspected along with your tow hitch by an experienced “ meat & potatoes “ trailer repair/hitch installation/welding shop. If you haven’t had that done - schedule an appointment - it is also a good idea to have whatever trailer you are towing completely checked out as well. The frame - tongue - hitch - safety chains as well as the breakaway switch - trailer brakes - wheel bearings - spindles - hubs along with the tires & rims.. Jim
Anyone familiar with the fatality (and it happens quite a bit) from trying to pull a stuck truck with a cable and hitch. The hitch breaks if I remember correctly not the pin, but it send the remaining oart of the hitch right through the windshield killing it occupant. So remember that if ever towing a car off the hitch with a cable or strap if they lock up the brakes or get stuck on something.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
| The Following User Says Thank You to turbo69bird For This Useful Post: | ||
