#821
Old 02-06-2023, 07:06 AM
dataway's Avatar
dataway dataway is offline
Absolutely beautiful.
Let us know how the alignment goes ... I'm going to be in that spot shortely.
How long before we get time slips from the drag strip
  #822
Old 02-06-2023, 11:32 AM
Shiny Shiny is offline
That is exceptional. Two notches above wow.
  #823
Old 02-06-2023, 05:15 PM
bluejudge bluejudge is offline
That is amazing work Roger. Great job!!!
  #824
Old 02-06-2023, 05:40 PM
gorge...a fine fine ride you got there
  #825
Old 02-06-2023, 07:12 PM
gtospieg gtospieg is offline
Sweet...
  #826
Old 02-06-2023, 08:58 PM
roger1's Avatar
roger1 roger1 is offline
Originally Posted by gtospieg View Post
Sweet...
Thanks for the glowing compliments guys!
The dragstrip? I don't think so! Just easy cruising with this baby
The drive down to the alignment shop felt a bit squirrely at times but about what you would expect with no alignment done yet. Afterwards, it seemed like a different car. A world of difference. Took it up to about 65 and seemed to track straight. The Borgeson steering box feels great too.
So here is my alignment sheet:
The guy running the machine said it helped him out that I kept track of the shims and put the same amount back in after assembling the front end. He said it saves time when caster and camber isn't far off to begin with than it is when it's way off. The tow was pretty far off though which I expected. Hard to get close when just using a tape measure on the tire tread like I did. He said it all came out well from what he could see and he liked that steering box. Reviewing this now I wish I had asked about that rear thrust angle number. He didn't mention it but I was wondering if that is a high number or not. It must have been that way from the factory though.
Btw, here's the Caddo Alignment shop waiting room guard dog. Had some fun playing with him for a while.
I called the interior shop and he said bring the car on down so that's where it will be for a couple of weeks or so.
I drove the car on a stretch of road on the way just to get an idea how the car rides. I was extremely pleased as it took the bumps very well. I think the spring and shock combination along with the rear air bags is a great combination just like it is in my El Camino.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
  #827
Old 02-07-2023, 06:13 AM
dataway's Avatar
Roger, other than the steering box do you have any non-stock components in the steering/suspension (long time ago in the build thread ), any repop suspension components?
Other than replacing the original number of shims did you make any effort to adjust caster/camber ?
I'm thinking of trying to get as close as I can on toe, caster and camber before I take mine in ... it's a local garage and I want it to be a simple as possible for them.
  #828
Old 02-07-2023, 08:40 AM
roger1's Avatar
I made no attempt at adjusting caster and camber beyond keeping track of the shims that came out when I disassembled the front suspension. On toe, just used a tape measure on tire tread rib front and back. Just can't get it very close that way but it was only 4 miles to the alignment shop. Also, it's getting the shims close that saves work for the alignment guy. Toe is an easy adjustment even if it's off by a relatively large amount.
Not a huge amount of non-stock items. All the control arms and front sway bar are factory stock to this car.
KYB Gas-A-Just shocks on all 4 corners. These are the most economical choice of all available mono-tube design shocks which are superior to the twin tube design.
Non-stock items up front:
Moog 5273 coil springs
Energy suspension polyurethane control arm bushings
Energy Suspension polyurethane sway bar and end link bushings.
Rear:
Air Lift 1000 #60744 air bags (10psi) inside factory stock coil springs
Boxed-in lower control arms.
Frame to upper control arm braces
1" rear sway bar
Also keep in mind that I've probably reduced the weight in the front by using an aluminum radiator, A/C compressor and intake manifold. Mini starter too. I'm guessing a 100 lb reduction over stock over the front wheels.
  #829
Old 02-07-2023, 12:54 PM
dataway's Avatar
Thank you. Yep, reduced weight and probably the new springs are probably all that would affect alignment ... well, depending on if it had ever been realigned to compensate for worn bushings etc.
I'm probably going to buy a cheap caster/camber tool and get as close as I can. If my local garage can't do alignments then it's going to be a 20 mile drive to a place that can.
  #830
Old 02-11-2023, 09:30 PM
Skidmark's Avatar
Skidmark Skidmark is offline
So nice to see your car back on the road. The interior turned out awesome. Same for the fit and finish of the panels.
The Following User Says Thank You to Skidmark For This Useful Post:
  #831
Old 04-16-2023, 09:07 PM
Andretti's Avatar
Andretti Andretti is offline
Roger, I would really like to see some outdoor springtime pictures of that labour of love. Knowing you a little, you've probably got a million and one chores going on right now but please, take the time and crown this - #1 - PY thread using your awesome photography skills!
  #832
Old 04-17-2023, 06:32 PM
roger1's Avatar
Thank you for your nice compliments! Yes, my time has been occupied. Both my wife had to travel out of state for quite a while to help out with a family medical matter. I've been back for a bit but my wife is still there helping out.
Boy do I wish I could get those springtime photos. I'd love to be driving around with the top down with my hair blowing in the wind. But, not there yet. The car is still at the interior shop. I was hoping he would be about done by the time I got back to town but he wasn't able to put many hours into it. Some progress though. I was over there today and snapped these photos.
I also made a little progress on the car today while I was there today. I brought over some tools and got all the A/C hoses cut and fittings crimped on. Then installed them. I think it came out pretty nice.
This is the fitting I ordered for the back of the compressor:
For the suction hose, I used #10 reduced barrier hose and there is a #12 to #10 adapter connected to the receiver/dryer. The compressor outlet hose to condenser inlet is a #8 reduced barrier and the line from the condenser outlet to the inlet at the evaporator (where the orifice tube is) is a #6 standard size barrier hose. I ordered all these hoses and fittings from Coldhose.com except for the #12 to #10 adapter on the receiver/dryer. That came from ICT Billet
Btw, I did have to fabricate an adapter to be able to connect the #6 hose to the 1969 style condenser outlet. That outlet is meant to hook directly to a dryer whereas the more modern style system I've chosen needs to have the hose connected directly to the outlet.
To make this adapter, I cut the fitting off of the top of an old dryer, cut the middle out of it where the site glass was and welded it back together.
  #833
Old 04-17-2023, 07:13 PM
wagzilla's Avatar
wagzilla wagzilla is offline
Default A/C crimps
Boy Roger, that looks so much better then factory, You really knocked this one out of the park!! nice job!
  #834
Old 04-18-2023, 06:36 PM
roger1's Avatar
Thanks for the compliment James! Also thank you for the guidance you've given me while I've kicked around my ideas for this system. Next test will be to getting it pumped down and see if it holds a vacuum OK.
  #835
Old 05-06-2023, 07:29 PM
roger1's Avatar
Just a quick update:
I dropped by the interior shop yesterday. He has gotten a ways further on my convertible top installation. He had to modify the pads to get them to fit the way he wanted. He said it took some doing to get them that way but they are permanently installed on the top frame now. He's was fitting the rear window assembly when I got there. He said he is going to do some modification on that too so it will come back off and go on his sewing machine table. He's a perfectionist for sure.
Good news from him. He was doing jobs on 2 other cars when I brought my car to him back in March. One he finished a couple of weeks ago and the other he finished this week. So now my car will get all his time until it's finished and expects to get quite a bit done on it next week. He doesn't work full time though since he's mostly retired. I'm guessing 4 hours a day or so. Anyway I hope to have another update here next week.
  #836
Old 05-06-2023, 10:38 PM
Do me a solid Roger; kindly ask your guy what they use in the channels to replace the cardboard that holds the staples.
  #837
Old 05-07-2023, 07:00 AM
roger1's Avatar
Sure. I will ask him what he prefers to use.
I know he thinks it's fine to leave the original in there if it's still in good enough condition. Since my car had never had a top replacement before now, a lot of the original was still fine to use.
He did replace some of it though. Some chunks were missing and I removed the front one entirely because I had to blast and paint that front section.
  #838
Old 05-13-2023, 08:59 AM
roger1's Avatar
I went to the shop yesterday and asked him this question for you. He said that he doesn't particularly like the new vinyl plastic ones that come in the tack strip kits but he will sometimes use them depending which channel they go in and how they fit. If it will fit a channel OK and it's not in an area that puts a lot of stress on the staples, he will use it. Other channels where is a lot of stress or need a more precise fit, he makes his own tack strip. He uses strips cut from 1/8" waterproof panel board. He layers the strips together with glue to give the thickness of the tack strip needed.
I didn't ask where he buys these but must be from some upholstery supply company he uses. I did a bit of searching and found that this is panel board commonly used for making custom door panels and found a source here:
https://www.roncofurniture.net/produ...rproof-32-x-48
Things are moving along well on the car. He said it took quite a bit of doing getting the inner lining at the corners of the rear window to fit the way he wanted. But so far he is very happy with the way the outside vinyl is fitting. He thinks he will finish the top next week and move on to covering the rear seat arm rest bases and well covers. Then he will install those parts along with the rear side panels and windlace. He's already put the seat backs and seat base shells on the front buckets so those are ready to be put back in after the rear seat area is done.
  #839
Old 05-13-2023, 09:36 AM
thank you - eventually I will need my top redone and that is an issue I noted the last time that would need to be addressed. The OEM setup looked like compressed cardboard.
  #840
Old 05-18-2023, 06:43 PM
roger1's Avatar
I went over to the interior shop yesterday to do some things regarding the A/C system and to check his progress on the top install. He hadn't worked any on the top but had started and completed installing the rear armrest covers and well covers. I was quite please to see he got those knocked out and they look perfect!
I also snapped some photos of the bucket seats with the backs and seat base covers installed:
I think my car will be getting out of interior jail soon! He was already getting back to work on the top before I left. Got my fingers crossed that he may get done with it by next week some time.
So while I was there, I tried to vacuum down the A/C system to see if I have any leaks. Wagzilla on this forum who has made a few comments in my thread here is an expert in auto and emergency vehicle A/C systems. He advised me to get a micron gauge for measuring vacuum instead of just looking at the A/C gauges. So I did that and this is my first time using it.
Here's what I got after pumping it down for more than 30 minutes:
I could only vacuum it down to this 7650 microns. It must have a small leak somewhere. I was looking to get this down to less than 500 microns. Not sure of my best approach to find the leak at this point. I can see why having the micron gauge is necessary though. My A/C gauge reads between 29 and 30 inches of vacuum. Without that micron gauge, I wouldn't know i have an issue somewhere.
The Following User Says Thank You to roger1 For This Useful Post:
