Old 05-20-2023, 07:34 PM
JLBIII JLBIII is offline
Default Chassis dyno numbers
Pulled the original 400 HO engine that was getting a little tired out of my 68 Firebird. In it's place put in a fresh build based on a '73 400 block with a 4.25 Eagle crankshaft, Comp 230/236 roller cam and 1.52 roller rockers. Pistons are Icon with a 30cc dish due to running a pair of stock, date correct 16 heads to keep it looking original along with a '68 intake manifold and RARE long branch exhaust manifolds. Kept the quadrajet but used a 800cfm model. Distributor has a Pertronix III module in it.
Numbers from the Dynojet were:
310 rwhp @ 5350 rpm
346 max torque @ 4450rpm
Car was built as a fun street cruiser running on pump gas with 3.36 posi behind a TH200R4.
The Following 4 Users Say Thank You to JLBIII For This Useful Post:
Old 05-20-2023, 11:12 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Those a nice numbers. Should be a lot of fun.
Go fast, see Elvis!
Old 05-21-2023, 06:23 AM
Sweet numbers!
If your foot is as uncontrollable as mine you’ll be replacing the rear tires in no time!
Old 05-21-2023, 10:24 AM
Lee's Avatar
Lee Lee is offline
Did you do any tuning? Optimizing the AFR and timing could be worth another 20-30 hp/tq.
My 455 makes slightly higher numbers, but at lower RPM (less CR, smaller cam, so as expected). I've got a lower restriction exhaust, and a LOT of tuning (EFI & ignition control).
My car is a '73 T/A clone, 3.08 gears and stock torque converter - it has ran 13.12 @ 103.2. With your lighter car and more gear, you should easily be in the 12's (with traction!).
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-21-2023, 10:42 AM
grivera's Avatar
grivera grivera is offline
OP - thanks for sharing. That combo is very similar to my LeMans which has 16 heads and pistons with a 29cc dish. What is the cam lift and LSA?
Will Rivera
Old 05-21-2023, 12:08 PM
Cam lift is:
.573 I
.578 E
112 LSA
Old 05-21-2023, 12:22 PM
We did some tuning on it. We tweaked the timing a little. The dyno operator was happy to see the a/f ratio averaging 13 at WOT with the Qjet.
Hope to get it to the track next weekend. Fingers crossed!
The Following 2 Users Say Thank You to JLBIII For This Useful Post:
Old 05-21-2023, 03:37 PM
mchell's Avatar
mchell mchell is offline
310 rwhp @ 5350 rpm
Looks similar to my old 455, iron headed(96 heads), hyd cam, qjet, RA manifold motor……was a decent street combo… ran somewhere in the 12’s at a 4000lb race weight
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
