Old 06-10-2023, 12:30 AM
1963cat 1963cat is offline
Default 63 b/w t10 output
In need of a output yoke for my 63 Catalina. Ten spline with 3r u joint I believe is correct. Also looking for poverty cap hubcap clips. Any leads would be appreciated. Thank you
Old 06-12-2023, 09:46 AM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
You may want to change the title to "driveshaft yoke" for more views.
Old 06-12-2023, 12:56 PM
misterp266's Avatar
I believe these clips are the same.
https://www.ebay.com/itm/40421039946...MAAOSwHkli--vJ
" Darksiders Rule "
Old 06-15-2023, 01:53 PM
Default Driveshaft yoke
Looking for driveshaft trans output yoke that will work on my 63 Catalina. Trans is a Borg warner close ratio T10 . Spline count is 16 and takes the big Pontiac 3r u joint. I got my spline count incorrect on my original post. Thank you
