#41
These recommendations from HO racing in the early 70s should interest many here in this string and if I am not mistaken they where inferring this along with compression ratios of over 9 to 1.
Maybe Ken from HO racing days can confirm this inference?
| The Following User Says Thank You to steve25 For This Useful Post: | ||
#42
Pontiac did away with 744 cam in mid 1969 I believe. They were having complaints about cold start rough idle in Northern climates. Before that the four speed cars with 48 heads came with the 744 cam (and stiff valve springs) and automatics got the 068.
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
#43
What publication is that from? (and what pages please) Over the years I have bought any vintage Pontiac stuff I have come across; I do have one HO Racing book (engine blueprinting), but that is not in it. Quote:
I have heard that someone close to McCarthy is here, but have never seen anything from the man himself; (or noticed anything inferred to be second hand either) I have also never seen any posts which I understood to be from any of the speed shops of days gone by... I used to on occasion just imagine being around in the heyday of when all these great cars and engines were around... The best I can now do is try to be financially smart, get a bigger garage, and maybe some day have a couple different Pontiacs to choose from. (as long as the prices don't keep going skyward.)
#44
Maybe Ken will way in on what he may sell now.
This is from the Elgin version of the 744 they sold many years ago _______I__N__T__A__K__E Rocker_Arm_Ratio_=_1.650_________Valve_Lash_=_0.00 000 VALVE_____Lift______Opens___Closes__Duration _________________Deg_BTDC__Deg_ABDC_____________Ar ea _________0.00000____50.30_|_121.70_|_352.00_|__38. 00 _________0.00400____32.22_|_101.59_|_313.81_|__37. 96 _________0.00600____28.14_|__96.18_|_304.32_|__37. 94 _________0.05000_____4.38_|__55.67_|_240.05_|__37. 24 _________0.10000____-7.29_|__43.59_|_216.29_|__36.30 _________0.15000___-16.73_|__33.82_|_197.10_|__35.15 _________0.20000___-25.70_|__24.73_|_179.03_|__33.54 _________0.25000___-34.98_|__15.37_|_160.39_|__31.24 _________0.30000___-45.04_|___5.30_|_140.26_|__28.43 _________0.35000___-56.81_|__-6.47_|_116.72_|__24.46 _________0.40000___-72.03_|_-21.72_|__86.25_|__18.76 _________0.44500___-98.73_|_-48.32_|__32.96_|___7.18 CAM_______________________________________________ ______ICL _________0.00400____27.12_|__94.68_|_301.80_|__22. 99_|_123.78 _________0.00600____22.73_|__86.21_|_288.94_|__22. 96_|_121.74 _________0.05000____-3.64_|__47.30_|_223.66_|__22.23_|_115.47 _________0.10000___-19.42_|__31.10_|_191.68_|__21.00_|_115.26 _________0.15000___-34.50_|__15.85_|_161.35_|__19.09_|_115.18 _________0.20000___-51.81_|__-1.50_|_126.69_|__15.88_|_115.16 _________0.25000___-77.01_|_-26.67_|__76.32_|__10.13_|_115.17 Stan
| The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#45
Yes,,,when I bought my GTO the motor had never been touched internally. Still had the 068 'S" cam and nylon covered timing chain. With that cam it idled like a kitten but had a good low rpm pull. Now a RA4 sized cam with Rhoads and its only a little choppy,,,still pretty smooth.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' Last edited by scott70; 06-15-2023 at 12:28 PM. |
| The Following 2 Users Say Thank You to scott70 For This Useful Post: | ||
#46
Early 2000's ish ..... Definetly after 1998.
#47
I went out today to look and see if I still have the box from that cam (I can be something of a packrat);
I first looked at my machine shop paperwork and it didn't list it; But I did find a little note that I wrote in pencil at the time - I believe I was trying to get the spec's on this cam, in spite of it not coming with a cam card. I want to say it might have been a 'Wolverine' brand - but I could very well be wrong; I do recall that the machine shop had to do a lot of looking around to find it, and I believe it was a brand, or from a warehouse that was closing down... So I next went out to the garage to where I have camshafts stashed; I decided to look at the cams i had tucked away in case I recalled what they were incorrectly, and in doing so I surprised myself. I clearly recall that when I was looking at the cam that I replaced, that it was stamped with an "A", and to this point, I had assumed it had a replacement cam... but It looks like the "A" stamp was on the wrong end... I now know that the OE Pontiac grinds have the stamp on the front, and looky-looky!?! I don't recall noticing that stamp before! Now I want to buy a degree wheel to measure and confirm what I have! --- EDIT: I just did some searching, and it looks like Wolverine did go out of business - not sure when. Maybe my cam was a Wolverine grind(?) Does anyone have an old Wolverine book? One of my google searches brought me back here, to THIS thread. Does 171R sound like a grind number? (this guys receipts could be misleading - sometimes he used part numbers, sometimes it was his own code.) Maybe I'll just have to pop open my engine one day.
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 06-15-2023 at 05:58 PM. |
#48
https://partshawk.com/melling-spc-3-...-camshaft.html Scroll down to the interchange on this page and the Sealed Power cam has that same number.
| The Following User Says Thank You to 400 Lemans For This Useful Post: | ||
#49
/\ thanks!
That’s some awesome sleuthing there!! I’d wager he used the sealed power number on his sheet, but was only able to find the Wolverine part. I remember there was some story of him having genuine trouble locating that grind for me. Does anyone know when Wolverine was incorporated into Crane (which has since been incorporated into Comp!)?
#50
Wolverine's parent company was Crane.
I'd think you have a true RA III copy camshaft. Not many places offered a copy of that cam. From what I've seen all of them were the same as the Mellings cam. Not all 068 and 041 cams are the same. There is more than one copy of them. If you look closely at your S grind you can see the peeks of the lobes appear to be a little flat. The RA III is more pronounced. It's the only cam I know of that can almost be visually identified. I measured the dwell at max lift and I want to say it was at peak for twelve degrees. There is a post on the site that has pictures of this cam. I'm pretty sure it was posted by Ken Crocie (the owner of H-O racing). |
#51
Just an idea. Gach recommended the 60919 Crower cam and what little I got to drive it it was a nice cam. I will be using it again in this incarnation of my engine.
#52
This is some information that I got from Rocky about 5 years ago.
PS - Let me add this is what the nose of the lobe lift data for the Elgin cam looks like.
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 06-16-2023 at 10:01 AM. |
