#781
Old 04-20-2023, 07:55 AM
poncho4554spd poncho4554spd is offline
Originally Posted by necdb3 View Post
How's Glenn's car going?
It's still unfinished and sitting in my friends garage. He has been asking me to get back over there. I have been a little busy thinning out my herd of parts and other projects while helping my son build his truck and trying to get some work done on my 74 superduty project. I am hoping to give him a hand in rhe summer to get thie thing going back down the road and able to be enjoyed again. I will post as soon as there is some noticeable progress on the car.
  #782
Old 06-06-2023, 05:30 PM
Ok, quick update on the car. It has been in my buddies garage unfortunately collecting dirt and cat prints. He has a lot going on and the car isn't top priority. I removed the interior from the barn and cleaned it up and put in plastic till installed. In the mean time I sold my major project 70 trans am and all of the parts I had acquired for the restoration. Since selling the car and parts, it got me thinking about this car and the work I previously performed on the car. So basically I made a deal with my buddy and used the proceeds from my 70 and parts to buy this car from him. So much for thinning my herd lol.I have a set of decals on order along with new carpet. Once I get the car cleaned up and start assembling again, I will post.
ID:	613825   Click image for larger version
The Following User Says Thank You to poncho4554spd For This Useful Post:
  #783
Old 06-07-2023, 05:52 PM
Ramairnacho Ramairnacho is offline
Nice car! My cousin had a 72 ta ho 455. It had an aluminum intake and nice heads. He crashed it when he was 16. He gave me the heads and about 10 years ago the neighbors iron scraper stole them from me. I like your new project!
  #784
Old 06-07-2023, 06:33 PM
Thanks! I am.looking forward to continuing the process of putting it together and getting it back on the road.
  #785
Old 06-16-2023, 06:55 PM
Just wanted to do a quick update.I took an inventory of what's still with the car and what is missing.. I.started cleaning the dirt from the car and all of the parts that accumulated from sitting in my buddy's barn.. I have been slowly doing a little more work on the car. In the mean time I ordered carpet, decal kit, shaker wiring, rear emblem letters, headliner kit and other misc. Parts. I tried starting the engine today. But it is starving for fuel and the pump is barely pushing so I will add a new fuel pump to the list. I
  #786
Old 06-16-2023, 07:02 PM
I did sandblast the front wheel wells and brackets. They were then primed with Diamont 2 part epoxy.
ID:	614315   Click image for larger version
ID:	614316   Click image for larger version
ID:	614317   Click image for larger version
ID:	614318   Click image for larger version
  #787
Old 06-16-2023, 07:08 PM
I cleaned the dirt from the seats in preparation for the interior install hopefully soon., along with cleaning the lower valance before installing
ID:	614320   Click image for larger version
ID:	614321   Click image for larger version
ID:	614322   Click image for larger version
ID:	614323   Click image for larger version
  #788
Old 06-16-2023, 07:14 PM
Front lower valance and spoiler and a pic of the nose installed on the car before I pulled the car out and rinsed off. I still need to do some final fitting on the nose and hood to make it right
ID:	614325   Click image for larger version
ID:	614326   Click image for larger version
  #789
Old 06-16-2023, 07:27 PM
I wanted to prepare the rear bumper for installation. It was a bit dirty and had some slight surface rust on the inside and the brackets were rusting. Since it is not perfect but is straight and was fitted to the car prior and this car will be driven frequently I chose not to completely remove everything but at the same time I wanted to do something. I did a polish on the outer chrome side then scuffed and treated the rust on the inside. Next I taped up the bumper and painted the inside area with seymour stainless steel paint, the taped out the mounting brackets and sprayed them black
ID:	614328   Click image for larger version
ID:	614329   Click image for larger version
ID:	614330   Click image for larger version
ID:	614331   Click image for larger version
  #790
Old 06-16-2023, 07:34 PM
More bumper pics
ID:	614333   Click image for larger version
ID:	614334   Click image for larger version
ID:	614335   Click image for larger version
ID:	614336   Click image for larger version
  #791
Old 06-16-2023, 09:38 PM
70TA-RAIII 70TA-RAIII is offline
That bumper turned out nice! How did you clean the INSIDE of the bumper? Mild sandblast? Looks good.
John
70 TA RAIII M20 05D
70 TA RAIII M20 06B
  #792
Old 06-16-2023, 10:27 PM
John
Thanks. Normally I would of Blasted it with 000 sand but after hitting it with a red scotchbrite and some 400 grit sandpaper it looked pretty decent so I hit it with some RM 801 metal conditioner which is phosphoric acid and water mixed. Then I painted. With the seymour stainless steel and finished the brackets in black.
  #793
Old 06-21-2023, 03:13 PM
The door guts have been installed and some assembly on the rear of the car has been completed. Next step is the rear glass, door glass , roof channel installed and weatherstrip.
ID:	614595   Click image for larger version
The Following 2 Users Say Thank You to poncho4554spd For This Useful Post:
  #794
Old 06-23-2023, 07:24 PM
I stripped the door mirrors and marker light bezels and put in epoxy primer. They will get painted next along with the rear spoiler and wheel flares, then installed.
  #795
Old 06-23-2023, 07:29 PM
The glass is in the car though I still have some adjustments to do on the door window tracks. I dug upnsome barrel/tubular nuts and put the letters on the tail panel
The carpet and interior are next on the list.
ID:	614763   Click image for larger version
ID:	614764   Click image for larger version
ID:	614765   Click image for larger version
ID:	614766   Click image for larger version
  #796
Old 07-04-2023, 06:19 PM
Final batch of parts prepped and in paint
ID:	615360   Click image for larger version
ID:	615361   Click image for larger version
  #797
Old 07-04-2023, 08:14 PM
In the interim, started some interior and was able to get the carpet, seat belts and seats put in
ID:	615373   Click image for larger version
ID:	615374   Click image for larger version
  #798
Old 07-04-2023, 09:16 PM
Couple pics before the remaining parts are installed. on the body
ID:	615383   Click image for larger version
ID:	615384   Click image for larger version
ID:	615385   Click image for larger version
ID:	615386   Click image for larger version
  #799
Old 07-05-2023, 10:01 PM
Looking great
  #800
Old 07-06-2023, 09:29 AM
Originally Posted by Tellyshavilli View Post
Looking great
Thanks Matt. I.can finally see some light at the end of the tunnel as far as getting this thing back on the road. I still have some small mechanical and wiring issues in addition to the finishing needed on the body but the car will start up and can be driven down the road. Hoping to get the final pieces on the body and block and buff the clear soon then do the decals.. I did leave some of the stuff on the car that Glenn previously posted about in his thread even though was either not correct or original to the car build such as the unitised distrubutor, chrome valve covers and deluxe interior. This car will be driven and the original plan was for it to be a nice driver that will see the road fairly often so I am fine with not being totally correct for the original build. Just want to finally cruise it lol.
