Old 06-22-2023, 01:59 PM
i82much's Avatar
i82much i82much is offline
Default Intake and port work recommendation
65 GTO hardtop, 3.54 gears, 28" tire, ultra wide ratio muncie. Old Faithful 1.0 cam and 1.5 rockers, unported 87 cc edelbrock heads with old-style chambers. 850 double pumper, doug's headers. Street car.
Engine is 505 CID IA2. I own an unported RPM and unported Torker 2 intake.
Would it be worthwhile to send the heads and either intake out to get port work done? And if so, is this combo too mild to benefit from a Northwind? Should I go all the way to 340 cfm, 325 cfm, how far out should I go if I have the heads ported?
Old 06-22-2023, 02:17 PM
Gach's Avatar
Gach Gach is offline
It all depends on what your intentions are with a Car. What hp range your looking to be in.
Old 06-22-2023, 02:37 PM
jhein's Avatar
jhein jhein is offline
Seems like with 505 cid, it would want a better flowing intake and heads. But then you would also need a much bigger cam too (the OF also seems small for a 505 no matter what), otherwise I wonder if just the intake and porting would matter very much??
Old 06-22-2023, 02:38 PM
Stan Weiss's Avatar
How about some more information about your engine? Without knowing CR it is a little hard to spec parts, but with your ci I would think a Road Paver might be a better cam choice.
Stan
Pontiac Pump Gas List
Old 06-22-2023, 02:44 PM
i82much's Avatar
Stan
sorry, forgot that part - it's very close to 10:1. I run 92 ethanol free but may switch back to 93 e10 and use an additive to prevent corrosion. 2000 feet elevation in Spokane.
Old 06-22-2023, 02:50 PM
steve25 steve25 is online now
Let’s assume the heads flow 275 cfm@28” ( about average for out of the box ) at .550” lift.
That’s enough to make a super easy 525 Hp through a gasket matched T2 or the Performer rpm with your CID while having excellent drivability with 3.5 series rear gears.
Now let’s say your shooting for 600 Hp.
Now the heads will need to be ported some so that you have between 290 and 300 cfm available at the lift your cam is providing.
At this point also the Performer rpm should get left behind and the T2 ported some besides the gasket match and a 1” blended carb spacer used.
So now the question is do you have the hood clearance for that while running a decent air cleaner?
Old 06-22-2023, 02:57 PM
i82much's Avatar
pretty sure I have clearance for a T2 and a 1 inch spacer, the RPM is on the car now. I didn't notice much difference between the two intakes, but we know how butt dyno's are ...
The road paver recommendation is intriguing because then I start to wonder about whether a beehive spring and light retainer might let me buzz it to 6000 RPM or so safely, I have the rev limiter set at 5500 now and it seems to fall off right about then anyway.
Old 06-22-2023, 03:14 PM
mgarblik mgarblik is offline
Related question: I have never heard of an ultrawide ratio Muncie trans. Does it have a different gear set than a 2.56:1 ratio?
Old 06-22-2023, 03:31 PM
i82much's Avatar
Yeah it's called an M23Z, a Muncie supercase with 1.000, 1.468, 2.043, 2.994 ratios.
I got mine before the N cases came out so it's the older supercase.
Old 06-22-2023, 03:41 PM
Since you might change cams and have to check and adjust your geometry just due to that I want to ask you to take full advantage of those Aluminum heads and cut them to get over 10 to 1.
Old 06-22-2023, 03:43 PM
77 TRASHCAN's Avatar
Steve C. Has a 505 combo, I am sure he has some experience to help.
My knowledge gained here, and from others...a dual plane intake loses its advantage over a single plane, the larger the cubes are...a 505 needs the T2.
I wonder what others think the choke point is on your current combo?
I really don't think it is the cam......
The cam core availability situation would push me away from a cam change, at least until things improve. If...
Don't get too crazy the the HP..
Might be too much, when you're running your mudgrips!!!
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 06-22-2023, 03:50 PM
i82much's Avatar
Yeah I mean the car is already unreasonably fast for any sensible person ... but I guess dorking around with your hot rod is half the fun so ... it's always fun to think about changes I could make.
Want to keep it nice and drivable and reliable so that's the main thing, but I think another step up would still be pretty livable ... maybe add a gear vendors at some point ...
Old 06-22-2023, 03:52 PM
i82much's Avatar
I am gonna drive this dang car as much as I possibly can ... I don't know if I'll ever get around to mud flaps and snow tires in the winter but that sounds a hell of a lot more likely than obsessing over making it look perfect!
Old 06-22-2023, 04:59 PM
Steve C. Steve C. is offline
When I first put my 505 together I dyno tested with a Performer RPM intake and a Victor intake. Both manifolds were port matched to the heads in use and both tested with the same custom HP950 Holley carb. The only difference was the RPM intake had a 1/2" carb spacer and the Victor had no spacer because of the hood clearance issue. The RPM intake was a disappointment with only about 615 HP at 5800 rpm. The Victor depending on the pull made 638-642 hp at 6000/6100 rpm. This was with a custom Crower solid roller cam with 260 degrees intake duration. When I went from the previous 4.210" stroke 462 CID engine to the 4.250" stroke 505 CID combo I added 6 degrees intake duration. The 462 engine used a 254 degree solid roller cam. On both engines the RPM intake made peak power at 5800 rpm and the Victor made peak power at around 6000 rpm.
After that dyno session we decided to change the cam. I got rid of the Crower cam and put in a UltraDyne MSP solid roller cam from Bullet Racing Cams rated with 255 degrees intake duration and went from .4200" lobe lift to .4300" lobe lift. Both cams had a 110 LSA. For the most part no other changes were made except we cut the Victor intake carb flange down 0.650" to help with the hood issues and the engine was dyno tested again. This time knowing the combo thrived on the single-plane intake we never bothered to test with the RPM intake. With the new cam it made about 660 hp at the same 6000 rpm. The engine uses Edelbrock heads with about 320 cfm and it only has 10:1 compression.
Old information here:
Old 06-22-2023, 05:45 PM
Gach's Avatar
So there was probably a 30 cfm drop with RPM intake so actually only saw 290 cfm, it pick up with Victor because more plenum and maybe only 15-20 cfm drop. Then going to 505 which is 43 more ci. So going to 430 lube really didn’t do much. Mostly pick up because of 43 more ci. Its like a 462 ci with what you think is a head that flows 350 cfm is not going to make 700 hp more like 660 hp.
Old 06-22-2023, 05:51 PM
Gach's Avatar
Until you understand how it all works you’ll be swapping cams…intakes from now until the cows come home. And spent twice the money. Another idea going from a port matched intake to a fully port and pick up 30 more hp. So now as example that 330 intake now actually flows 330 cfm.
Old 06-22-2023, 06:08 PM
If it were me I'd want more cam in a 505 as the old faithful is on the small side for that engine.
With that said I wouldn't want to bother with head and intake work if a cam swap isnt in the cards.
I would however want a single plane intake on an engine that large even as it sits now, preferably with a spacer. Bottom end torque would not be a concern with an engine that size.
Other than that, without a cam change I'd be inclined to leave it alone.
https://youtu.be/XqEydRRRwqE
I mentioned horsepower in the previous post. Now looking at the torque curve for the two intakes on my 505. Again on the first dyno session.
I discounted the pulls under 3800 rpm, some numbers looked a bit erratic.
At that 3800 rpm the RPM intake was up 27 ft. lbs. torque over the Victor intake. At 4200 rpm they were dead even with the exact same 625 ft.lbs. torque. The RPM intake made it's peak torque at 4400 rpm and here is where the Victor intake started to make more torque over the RPM intake.
The Victor intake made peak torque at 4400/4600 rpm depending on the pulls with 635-639 ft.lbs. torque. At 5000 rpm the Victor was up by 19.1 ft.lbs. torque, at 5200 rpm up by 23 ft.lbs torque.
At 5800 rpm the RPM was down 18.6 ft.lbs. torque, and this was where it made peak power with 615.5 HP.
The Victor intake continued to make peak power up thru 6000 and higher rpm, depending on the pull. On the previous post I stated a best of 642 hp but looking again I found a dyno sheet with 647 hp at 6200 rpm.
( side topic... I mentioned a change to the use of a UltraDyne MSP solid roller cam after the Crower cam. By no means is this any type of recommendation here ! That was UltraDynes most aggressive series of solid roller cams and I had some roller lifter issues using it. In an effort to run a less aggressive cam and to lessen the spring pressure but with the same 255 degrees intake duration I worked with Tim at Bullet Racing. I no longer have the MSP roller )
Old 06-22-2023, 06:58 PM
From the internet.... While longer runners tend to work well at the lower rpm range, shorter runners favor the upper range of the rpm band. Plenum size also has a dramatic effect on power production. Smaller plenums, like those in a dual-plane manifold, do well in the lower rpm range while larger plenums, like the single plane manifolds, tend to boost the top end of the rpm range.
As cast average runner length:
Performer RPM intake - 6.28
Torker II intake- 6.06
Victor intake- 8.82
As cast average plenum volume (cc):
Performer RPM intake- 1400
Torker II intake- 1195
Victor intake- 946
( My 4150 Victor intake has no plenum work, only a port match and light runner blending. It has supported a 4.125" stroke/450 CID combo at 7000 rpm with 684 hp. With a Brad Urban Carb Shop Stage III Holley 750 carb )
Old 06-22-2023, 07:03 PM
Gach's Avatar
You hit the nail on the head.
The Following User Says Thank You to Gach For This Useful Post:
