Old 06-22-2023, 10:35 PM
i82much's Avatar
i82much i82much is offline
Originally Posted by PunchT37 View Post
Running 1.5`s. 1.65`s puts it at 660 lift. This is a street car. Crane 99893 spring.
i am impressed by how high it revs, you always hear hyd rollers won't pull those rpm's ....
Old 06-22-2023, 10:43 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I’ve got the box at 6500. 5800 to 6000 seems to be it’s “happy place”.
Old 06-22-2023, 10:52 PM
Oh there are hydraulic rollers these days that will turn 8000 rpm and live. They get pretty in depth with lobe profiles and lightweight parts.
I turn my hydraulic rollers up to 6500 without a problem, at least the ones that make power up there anyway.
https://youtu.be/XqEydRRRwqE
Old 06-22-2023, 10:58 PM
i82much's Avatar
i thought pontiacs needed beehives and titanium retainers to pull 6500.
Old 06-22-2023, 11:07 PM
PunchT37's Avatar
Mine don’t.
I will say, after 6200, you can feel it fall off. So, on 505 cubes, 5700 to 5900 is prolly the happy place. So, beehives shouldn’t be mandatory.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 06-22-2023, 11:08 PM
Possibly. Lightweight parts are always a good idea, and the valvetrain on a Pontiac is a bit on the heavy side to start with anyway.
6500 wouldn't be that hard to pull off though with a hydraulic roller as long as the engine is making power up there.
We don't have any of the beehive stuff on dad's 571 Pontiac. Those heads were converted to a 2.19 intake valve which is a bit heavier, then had Paul spec the dual springs for the Hydraulic roller, I set them up at the install height he recommended. 160 lbs. seat pressure and 420 open. I think the retainers are titanium though. Dad repeatedly puts that thing on the chip, the engine revs up quicker than he can shift the darn thing. Has a 6300 chip in it and he's all over it all the time. It runs right up there no problem. On the dyno it was done making power however at 5800 rpm but still carried nicely just past that.
My chevelle has slightly heavier valve train (BBC) with a similar dual spring setup. 2.25 1.88 valves that aren't fancy lightweight stuff. Again it does have titanium retainers. BBC's are horrible about valvetrain weight and can sometimes have valvetrain issues as well. Hydraulic roller and it zings right up to 6500. Made peak power at 6300 but runs best times when I shift at 6500. Rev limiter at 6800. That engine has been together 25 years doing that LOL
