| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Does the engine run the same, (bog), no matter what the temperature is? Trying to figure out if closed/open look has anything to do with the bog. Basically cold, open loop, fuel delivery is primarily determined by MAF, temperature of water and air and throttle position. Once in closed loop, (warm), the front O2 sensors become the primary inputs for fuel delivery, but the other sensors are still used for fuel trim. If it runs the same cold and hot, (open and closed loop), again the MAF comes into question. You will get it!
| The Following User Says Thank You to firechicken For This Useful Post: | ||
If you start putting unknown manufactured parts on, especially computer controlled components it'll lead you down the wrong path. Only change 1 at a time to confirm or not the parts effect on the problem. It could also be wiring or connector related. I'd grab those at the bone yard if available, new ones are pretty costly and rare to find new OEM. Also grab a factory manual for the vehicle on Ebay. Good luck.
https://www.flickr.com/photos/197745168@N07/ "Of all ignorance, the ignorance of the educated is the most dangerous. Not only are educated people likely to have more influence, they are the last people to suspect that they don’t know what they are talking about."Thomas Sowell |
