#441
Old 07-07-2023, 08:51 AM
wizard61 wizard61 is offline
Will do Frank. Thanks
James
  #442
Old 07-10-2023, 09:57 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
We got our Polar White welting today James, Thank You, much appreciated sir!
1978 Trans Am
Pump Gas 461 Stroker
  #443
Old 07-11-2023, 11:20 PM
Glad you liked it. Thank you again for your support.
James
The Following User Says Thank You to wizard61 For This Useful Post:
  #444
Old 07-14-2023, 09:04 PM
WELTING UPDATE 7/14/2023:
Currently Available Colors:
Buccaneer Red: https://www.ebay.com/itm/165767811161
Cameo White: https://www.ebay.com/itm/165781756588
Starlight Black: https://www.ebay.com/itm/165633977660
Lucerne Blue: https://www.ebay.com/itm/164925318849
Platinum: https://www.ebay.com/itm/165929817785
Polar White: https://www.ebay.com/itm/166212838003
Brewster Green: https://wwwebay.com/itm/166228706702
Admiralty Blue: https://www.ebay.com/itm/166228708347
First Article Samples for Brewster Green and Admiralty Blue arrived and have been approved. I have added them both to the list of my Buy It Now auctions. There are only 2 each available right now, but more to follow in 3 to 4 weeks.
Polar White's Production is scheduled to arrive tomorrow. I will be adding more quantity to that auction as well.
I also received some a Sterling Silver Paint sample and compared it to the platinum. They are so close to each other that I think the Platinum Welting will look very good on a Sterling Silver car. I do not have access to a Sterling Silver car for comparison, so if anybody with one in original paint would like me to send you a sample for comparison, your help will be greatly appreciated. I have added a photo of the comparison. The large color plate is the Sterling Silver one.
Thanks,
James
ID:	616042   Click image for larger version
ID:	616043   Click image for larger version
ID:	616044   Click image for larger version
  #445
Old 07-14-2023, 10:45 PM
Stan65 Stan65 is offline
James,
Just bought the 2nd Brewster set on eBay. Will buy the 2nd when you get more in. Probably get a Buccaneer set while I’m at it. Lol.
Thanks,
Stuart “Stan” Landreth
  #446
Old 07-15-2023, 08:09 AM
johnta1 johnta1 is online now
Stuart, did you use the Lucerne Blue welting on your 71 Bird car?
  #447
Old 07-15-2023, 08:16 AM
John,
Yes used James’s Lucerne welting. Matched absolutely perfectly. Fit and flexibility is excellent. I used NOS flares and I think the flexibility was better than the original on the NOS flares and that allows a better fit even than the NOS.
  #448
Old 07-15-2023, 08:46 AM
Sounds good Stan. It will be 3 to 4 weeks for the production run to arrive.
Thanks,
James
  #449
Old 07-15-2023, 10:40 AM
Here is a pic of Stuart's car.
You have to see this in person, it is a work of art!
  #450
Old 07-15-2023, 11:55 AM
Absolutely beautiful!!! I’m going to have to get an earlier one. I seem to be stuck on the 73’s and 74’s.
James
  #451
Old 07-15-2023, 08:19 PM
WELTING UPDATE 7/15/2023:
Polar White: https://www.ebay.com/itm/166230104576
Polar White is Back in Stock and Relisted. Note the new Ebay #166230104576.[/SIZE]
Thanks,
James
  #452
Old 07-19-2023, 12:29 AM
spode spode is offline
Ordered 2 of the Polar white. Thanks for making these.
Jeff
  #453
Old 07-19-2023, 08:50 PM
Sooner70 Sooner70 is offline
I ordered the polar white today, perfect timing for me. I was on your list, not sure if you're keeping track. Thanks!
  #454
Old 07-31-2023, 05:17 PM
GOLDMEMBER GOLDMEMBER is offline
Thanks,
James
James - Any plans for Solar Gold??
  #455
Old 07-31-2023, 05:20 PM
Coming soon. Probably 5 to 6 weeks.
Thanks, James
  #456
Old 08-01-2023, 03:00 PM
Thanks, James
Thanks! Looking forward to seeing them on my '79!!
Eric
  #457
Old 08-01-2023, 03:46 PM
gilg gilg is offline
I Bought a set of White Welting on EBAY and my flares is ready to go, in your experience opinion what is the best glue to use welting to flares? thanks
1966 GTO - 1969 T/A Auto - 1974 T/A SD455 - 1977 T/A SE Y82 Auto T-Tops
1978 T/A Black W72 WS6 T-Tops NW - 1978 T/A Black W72 WS6 T-Tops VN
1979 T/A 10th Y89 4SP NW - 1979 T/A 10th Y89 4SP VN
1980 T/A Pace Car Y85 - 1980 T/A Turbo Y84 T-Tops - 1981 T/A SE Y84 Auto 5.0
  #458
Old 08-01-2023, 05:54 PM
There was a thread “best welting adhesive/glue to use?”. There were some good suggestions made in the thread. Try looking on the second page on this forum. It was a little while ago.
I have seen 3M high strength weatherstrip adhesive used, and it worked well. They adhered the welting to the flares, holding it in position with tape until it dried then bolted the flare on the car.
James
  #459
Old 08-03-2023, 04:09 PM
WELTING UPDATE 8/03/2023:[/I][/B]
The production runs for Brewster Green and Admiralty Blue are shipping tomorrow. I am hopeful that I can re-list their auctions next week some time.
The Second article for Solar Gold arrived and was approved! There is a new listing for the two samples I received on Ebay #166262274092. The production run will be ready in 3 to 4 weeks.
Thanks,
James
  #460
Old 08-06-2023, 12:07 AM
James
Thanks for reply after repaint my original flares and cleaning properly
try to glued the welting to the flare with this products
Permatex 80050 Clear RTV Silicone Adhesive Sealant Not Working
Permatex Super Weather-strip Adhesive Yellow Not working
3M Super Weather-strip Adhesive Black Not working
the problem is after apply very thing coating and wait about 3 minutes and reapply another very thing coating and wait about 24 hours the welting came apart not really glued, in the upper tips is the worst because the welting make 45 degrees in front and almost 95 degrees rear.
But surprise i clean again the flares and welting and use regular Krazy Glue with only few drops on the tips works in less than 2 minutes
started from the upper tips and glued only from the inside part of the flare with out bended the welting and wait about 5 minutes
and after bended and use very thin line all long from the inside part of the flare and glued perfectly with no mess at all.
after few days the welting still strong glued on the flares and the tips perfectly done that is the hard part, Just my experience Thanks
