Just be sure you do the adjustment right based on what the lifters instructions say, crimped nuts are only good for 2-3 times adjusting, 1 time is ideal. Can buy them at most local auto parts stores, just say you need rocker nuts for a 1978 350 chevy.
Heres a link to show how it can be done on smaller cams... for bigger cams its best to do when the cam is on the base circle for each valve. https://www.pontiacstreetperformance...p/rockers.html |
Lets say that cam was ground on a 108, you installed it dot to dot. per instructions. But never degree it, now for some reason (gear set ) being off, you check it ( degree it in ). And it comes in at 114 thats severely retarded. So now its not filling the cylinders hence the low compression reading. No matter what aftermarket cam it is, you just can’t take for granted that its actually on a 108. Also it may not be the case, the cam is off, but it could be timing gear set itself, thats why the offer timing gear sets with 9 key ways. Hoping now you understand why ever cam should be degree and checked to make sure. This would now eliminate the cause of that being the power lost. Then you could move on to valve adjustment valve train being problem. I mean you did a could job on checking all the obvious things.
| The Following User Says Thank You to Gach For This Useful Post: | ||
Moving onto valve adjustment, usually once valve is close ( with hyd lifters) you take up the slack, by turning push rod until there’s no slack, then go 1/4 or 1/2 turn what ever they recommend. It’s been a while since I’ve done hydraulic lifters so thats my vague memory. Its kind of hard to mess that up, only thing that could is if, even though you thought valve was completely closed, may not have been. So that would hold valve open, partially. Could happen on either intake or exhaust, so thats why I take the time to go though them again, just to check.
The other thing, with hyd lifters what I used to do, was put the lifter in a can of oil and pump it up. Because i’ve found that some times, if the lifter wasn’t pump up, now your adjusting it, taking up the push rod slack up, but it’s actually already depressing the plunger. Now you fire it off the lifter pumps up. But the valve isn’t completely closeing. But anyway definitely going with the studs and adjustable nuts is a plus, just assures a more solid adjustment |
