Old 08-11-2023, 06:49 PM
grd777 grd777 is offline
Default need HELP my door is stuck
my pass door is stuck i think the latch is jambed on the strike .the latch seems to work fine . what do i do, do i somehow have to cut it out
Old 08-11-2023, 08:09 PM
Formulabruce's Avatar
I "think" you said your latch is fine, but stuck on the striker?
So door is unlocked, and handle works the latch.
May try to pull up slightly on the handle and PUSH the door in and lift slightly.
hope that helps!
" Long may we DRIVE !"
Old 08-11-2023, 08:13 PM
hope that helps!
i think the door is to far in. just got it out from the body shop ,it worked there. at home maybe i slammed the door to hard .also maybe when we put it on the flat bed something happened
Old 08-11-2023, 08:16 PM
Could try to jack up right front, maybe some body flex will help. The little roller on the striker could maybe be lubed when you get it open.
Have the gaps changed> ?
Old 08-11-2023, 08:31 PM
SD73's Avatar
SD73 SD73 is offline
I haven't tried this, but the trick I recall from back in the day was to have someone hold up the handle on the outside, then from inside lay in the back seat and push out with your legs. Originally you were supposed to kick out, but I wouldn't recommend that unless the car was a beater.
Old 08-11-2023, 08:53 PM
yea no just got out of the paint shop, i may have to cut up the latch from inside the door (
Old 08-11-2023, 09:32 PM
cdnroundport cdnroundport is offline
You can get a torx driver in through latch and loosen stricker I have same think happen on a 72TA
Old 08-11-2023, 09:42 PM
VCho455's Avatar
VCho455 VCho455 is offline
We've used these at the shop to convince doors to open after collisions. Insert from the inside and pump up to lift door or move it forward or back.
https://www.homedepot.com/p/Calculat...697086#overlay
Since the car is just out of the body shop you should be able to see which door gap has closed up. If the gaps look good then the latch or lock linkage has fallen off. On my 72 I was able to look in from the top of the door with a flashlight and mirror and see that the lock linkage had fallen off and jammed the latch.
I had to watch the good side working before I could see where the problem was. I ended up having to remove the passenger seat and door panel to get mine open.
Good luck !
Old 08-12-2023, 03:15 AM
Trevor78 Trevor78 is offline
Don't cut a thing. Try jacking under the sail panel area, it may be enough to flex body and come free if you thump it.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 08-13-2023, 07:04 PM
71GP76TA 71GP76TA is online now
Have you removed the door panel?
Old 08-15-2023, 05:43 AM
just came out of the body shop ,no interior yet
Old 08-15-2023, 05:45 AM
tried that but no luck i did somehow got it open with a screwdriver.
thanks to all for the advice
