#241
What do you exhaust ports look like?
Stan
#243
Outer 2 on both sides are wet with oil/gas inner two on Both are dry
#244
Stan
#245
Oh I can’t wait to see what you come up with.
#246
Question for you when you put the new valve springs on did you change the valve seals.
#247
The original o rings were pretty much gone, I replaced them with the stock O rings
#248
I don’t know having good compression in all cylinders at least the amount should have, telling me its sucking oil from some where. Good possibility it’s valve seals. Being its happening in a few cylinders. Or valve guides … I have to be there seeing everything for myself to really diagnose what’s going on.
#249
Ok, O’rings not a good idea, I would definitely have new teflon valve seals installed. And check valve guides for where. I’m guessing this (could) be the issue
#250
If you can, take those cylinders that were getting oil in them, pope valve springs off and see, if those O’ring seals are still good, or if the moved up the valves.
#252
Oh yeah, I’ve seen this happen with a bad PVC system not working
#253
Question did car smoke out of the exhaust that you can tell.
#254
Only on cold starts pic is a rod bearing
#255
Did you put back on the round oil splash shields on the top of each valve spring ?
They must be used to control oil flow to the stems when your just using the stock valve stem O-ring and not a positive valve guide mounted seal. Bearing wise it looks like that with the level of oil dilution you where getting that spun bearings would have been in the cards soon! I would say you will want to add a crank polish job to your list of machine shop work.
#256
Yes I put the oil Shields in |
#257
Question, how was the motor running before you put new rings in and made cam change ? Just wondering if you where just making cam change what made you decide to hone and put new rings in.
#258
As a first step I would run a well WD-40 oiled up green 3M scotch brite pad up & down the cylinder walls to see how they look with just that level of work.
#259
Did you find anything worth talking about in the bottom of the oil pan?
What did you find when you cut open the oil filter? Stan
#260
Small flecks of metal, I'm sure that some of it is from the bearings and some is from breaking in the rings
