Sounds like it just had bad blow by time for rings at minimum.
I’d say just honing and putting new rings in plus adding more cam, which would have created more power. Didn’t work and won’t in doing it all over again. I would bit the bullet, and go .030 with new pistons and rings, also would put some good valve seals in there and get rid of the O’rings. Or else you’ll be chasing your tail.
The new cam created more dynamic pressure. ( compression) just adding to your issues and new rings didn’t really do much. I’m thinking what ever your piston to wall clearances were or are now isn’t good, new rings may of help temporarily. Also thinking if all was ok initially it would’ve been short lived. Its just not sealing up, weather is the rings or valve seals, or A combination of both….just honing and putting in new rings is like a coin toss.
Blowing oil in to air cleaner, from valve cover breather… that’s usually blow by. did you replace the PVC valve at anytime. I don’t know I’m lost on what else to tell you. Good luck.
