Yes the pistons were designed with a wrist pin offset and placed in the direction they were to quite the engine on cold start up. In the cases I have seen reversing the pistons at build time did no damage it just made the engine a little noisier. Remember almost all after market piston have no offset.
Stan
Saw this happen in the late 70s. Had a 67 GTO that was smoking pretty bad, so i tore it down for a rebuild. I thought it was still all factory but it had obviously been into before. The rods were mixed up to the crank and were tight. They had heated up so much that the big ends and caps had turned blue. Didn't spin any bearings though, but did have a very low, dull knock to the engine.
That is good to know! I am looking through my photos @ the bottom end, that are in my archives, to inspect the orientation of these Pontiac Rods in relationship to the Crank in this Engine. If I can't find the past photos, then I will pull the Oil Pan and look, 3 steps forward and 2 steps back, as usual.
Mikes reply: That is good to know also, thank you folks for all this spectacular input, makes for a more thorough investigation/decision on my part, there is no right or wrong way, there is only my way, at the end. P.S. The best thing to do is knuckle down and pull the Pistons, hone each Cylinder, then install new Bearings and Rings and never look back. Still on the Fence. I can tell you this, we are performing the Pontiac mod., as we speak, the holes in the Block are Taped and we are going out to find the 1/4" Brass/copper Plugs to fill them now. Last edited by TRADERMIKE 2012; 08-19-2023 at 02:25 PM. |
It turns out that the Block cooling holes were different sizes, so we opted to drill all three, in each Head, to the largest size 3/8" and then taped them /threaded. We found Ace was going out of business in Pompano Beach Fla., they had the 3/8" plugs in Stainless-steel, we used lock-tite to seal the threads and sent them lower than the Block. We elected to use good metal drills that I had used on the I-beam Boat trailer turned into a flatbed trailer. Ranging in 3 different sizes small, medium and say 1/4" ones, then we turned to my (round black) full kit, for metal only, for the final 3/8" cut. We then moved on to the 421 ci mod. , that is drilling the holes that are in the gasket on the 421 but not used on the 428, except in this instance. These holes are between the center exhaust Valves, my machinist that is remanufacturing the heads concurs that these holes do in fact meet in the Heads water jacket, but he did not drill them for me , so I will drill them myself. The Heads are not yet completed, but we keep on painting the Engine and compartment. We decided to pull the Fan shroud, so we can read the degree wheel better and paint the Radiator and forward Bulkhead area and then to the rear with a punch-out paint job. The degree wheel reads 1-1/2 degree, Advanced. I think that Butler had that added in because the Intake was 112 c/l and the Exhaust was 115 c/l thus: 115-112 = 3 divided by 2 = 1-1/2 degrees c/l built into this Melling "041" Cam, sold through Butler Performance Brothers. So, does that mean that the Cam position is correctly orientated in this motor, with the new advanced type Timing chain and Gear? We performed the degree wheel like this , with the Heads removed we installed the dial indicator over the high portion of the Piston top. We determined the top dead center as the piston came up to its highest point. The number one Piston and the Hydraulic Lifters are on the Base circle so, the Valves are closed on the compression stroke. We have Initial TDC. Attached wire hanger and pointed it over the Degree wheel zero mark. Turned the motor clockwise, the direction it turns in naturally, and 360 degrees later where at zero again, no slop in that direction. Now we turn CCW for 360 degrees and we end up on 1-1/2 degree advanced at the Crankshaft. Tell me if I am thinking correctly, the Cam is now advanced by 1-1/2 degrees Advanced and if I plan on adding more Advance, I could add say four degrees at the Crank and that would give me two up at the Cam plus the 1-1/2 = 3-1/2 total. So, I was told that I am at 113-1/2 C/L from the Melling factory by Butler, so, 113 -1/2 - 3-1/2 = 110. Now if I move the Timing at the Crank another two degrees advanced that would give me plus one at the Cam for (=) total of 109 that is my target advance, what do you think? The last thing I would like to say is that what if the person that built this Motor actually Blue printed and balanced the Crank shaft and Pistons for race reasons, I know that my father raced and he said he took his Engines for blue printing and balancing on the two Corvettes with 427 ci mills. If I screw around with moving the Pistons around on the Crank, I might just be interfering with perfection? Your thought on this new reasoning please. confused.... |
Did you arrive at TDC by taking measurements at .050" before and after TDC adjusting your wheel to arrive at true TDC? After you establish true TDC then you need to find the ICL by the same .050" before and after ICL and record the measurements. Then you can finally figure out whether your cam is advanced and by how much.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Here's a link to How To Degree Cam
You will need a dial indicator and the degree wheel at a minimum. What you have done is basically finding the TDC. Next would be finding the cam open/close specs and where they are at on the degree wheel.
| Closed Thread |
