#1761
Old 08-14-2023, 12:03 AM
Gach's Avatar
Gach Gach is offline
Yes its a stick….Its easy to lug it down with stick.
  #1762
Old 08-14-2023, 12:27 PM
64speed's Avatar
64speed 64speed is offline
Ignition box died, exchanging it for a 6AL.
  #1763
Old 08-14-2023, 02:58 PM
NeighborsComplaint's Avatar
That didn’t last long.. Made in Taiwan means nothing these days! Lol. Be happy you weren’t stranded. All this stuff is a crapshoot these days.
Triple Black 1971 GTO
The Following 2 Users Say Thank You to NeighborsComplaint For This Useful Post:
  #1764
Old 08-14-2023, 03:21 PM
64speed's Avatar
Summit BS, won’t buy one again. Bypassed it and fired it back up, yesterday it was cutting out at like 2800. I drove it this morning, went back to. Crank it and nothing. Returning it to Summit
  #1765
Old 08-16-2023, 08:00 PM
The bucking could have been intermittent ignition or other fault.
Also, I recall, you had to run a regulator due to the Holley mechanical pump putting out 10psi. If that regulator is dead-headed with no return line, the bucking (especially at slow speed steady throttle where engine demand is low slow) could be the source of the problem. The excess fuel and pressure has to go somewhere and it goes right back at the pump almost like a vapor lock. If it is still there after your ignition swap-out. I'd look there next.
  #1766
Old 08-17-2023, 02:44 AM
64speed's Avatar
It’s not at throttle but I definitely can’t cost in gear at a real low speed. The more I learn the more I find I know nothing an all but the cutting out seemed more like an electrical cut out. I will replace with MSD and report back. Getting mufflers today.
The Following User Says Thank You to 64speed For This Useful Post:
  #1767
Old 08-17-2023, 08:55 PM
64speed's Avatar
It’s starting to foul plugs and blow black smoke. I’m changing the plugs and hooking up the real MSD box tomorrow but where should I start with the plugs
  #1768
Old 08-17-2023, 08:58 PM
Gach's Avatar
What plus are you running now
  #1769
Old 08-17-2023, 09:01 PM
Gach's Avatar
I had that issue with NGK 8’s ended up ging with colder plug NGK 9’s. Not saying thats the issue but just out of curiosity what plugs are you running
  #1770
Old 08-17-2023, 09:21 PM
64speed's Avatar
I think they are NGK, I will get the part number tomorrow.
  #1771
Old 08-18-2023, 05:47 AM
Going colder fixes that? I would think going hotter would.
Gaps can be a concern, and personally, regardless of the parts config, I always run .032 for a number of reasons.
  #1772
Old 08-18-2023, 06:46 AM
64speed's Avatar
Edelbrock tech stands by their recommendation of Champion RC12YC. At 24 dollars all in I’m gonna give them a try. My exhaust shop recommended and ultimately installed Magnaflow 16 inch case mufflers. Quieter outside definitely but not so much inside cause I am still riding in a tin can. No drone though. I am concerned about the tic a little bit will tinker with it today or tomorrow. I have the plugs and the MSD box but won’t be able to install it till tomorrow. I will pop a valve cover and check all the rockers today for the tic. I am tired of chasing things though. If I can’t get it after a few days I will take it to a garage.
  #1773
Old 08-18-2023, 07:23 AM
The magnaflows are louder than the dynomax, and if not mistaken, the dynomax flow better too.
They sold you on a more expensive muffler. And it would have been better if they went to a larger case. Not sure you got your money's worth on that swap, if you wanted to get quiet, but it's done now.
You could have saved time by just going to the shop and telling them you wanted it quieter, and not just your time.
As for Edelbrock and calling tech support, the answer you get depends entirely as to who picks up the phone. Nothing 'wrong' about the Champions, just quality is all over the board with them in my experience.
  #1774
Old 08-18-2023, 10:17 AM
64speed's Avatar
Yeah I do feel like I was upsold but I had two people local tell me that’s what they were running and I always like the sound of their cars so here we are. They are clamped on so it’s not the end of the world but they will get changed if they are too loud with the interior in. It’s just so hard to tell inside cause everything rattles.
  #1775
Old 08-18-2023, 12:25 PM
I have used Autolite 3924s in my E heads.
The Late Model circle track car I had for a few years had dual MSD 6 boxes so during a race if one crapped out your could just turn a switch and use the other one.
  #1776
Old 08-18-2023, 12:31 PM
Va68goat's Avatar
Va68goat Va68goat is offline
I went with the Magnaflows on my GTO. I'm really happy with them and much better than the Flowmasters that I had before! This is a video that I found online. https://youtu.be/n61XIOVTmPk
  #1777
Old 08-18-2023, 12:37 PM
You could have saved time by just going to the shop and telling them you wanted it quieter, and not just your time....
As most of us were trying to tell you, so I won't belabor the point.
A pair of these with reducers to 2-1/2" will do wonders fitted in your tailpipes.
https://www.summitracing.com/search/...ype/resonators
The factory did these with automatics 68-69.
  #1778
Old 08-18-2023, 01:16 PM
64speed's Avatar
I don’t mean to say I don’t like the sound or it’s too loud it’s just that every damn thing in the car rattles right now so I can’t tell how they will be in the end. They are now quiet enough that I can hear the tic inside the car that o was only able to hear standing at the engine with the Black Widows.
  #1779
Old 08-18-2023, 01:34 PM
64speed's Avatar
Also you guys got to remember I am in a tiny town with a small exhaust shop. I can’t drive it 50 miles to another place to get it done and they won’t let you bring parts. You get what they have or you go somewhere else.
  #1780
Old 08-18-2023, 01:53 PM
None of these are options?
Getting all the rattles etc out is something that takes effort (and cost) during assembly. I made a point of it when doing the Judge & 442 project, and will do the same on the 'bird project. It's well worth it though, makes an incredible difference.
Doors and dash are focus areas.
