Old 08-21-2023, 12:37 AM
Tim Corcoran's Avatar
Tom,
While increasing the rod length does change the piston velocity curve, where in the velocity curve are you looking at when you say velocity has increased? Peak velocity is actually reduced as you length the rod. You also move the point of peak velocity and where the rod and crank journal are at 90 degrees to each other farther ATDC.
Stan
It is my understanding that with a longer rod the piston dwells longer at TDC and gives more time for cylinder filling and this also increases piston speed at some point in the stroke over a shorter rod. I don't understand your statement that peak velocity is actually reduced with a longer rod or maybe my understanding is flawed.
Tim Corcoran
Old 08-21-2023, 09:53 AM
Stan is pretty smart. Your build is one that has been done by probably everyone in the race section 20 plus years ago. The higher block fill will probably net you higher oil temps and lower cooling system capacity. I hope it runs well and lasts many years.
Old 08-21-2023, 11:47 AM
blueghoast's Avatar
I've got two motors that are hard blocked to the water pump holes
Both of these motors run cooler then any of my other engines.
On the street and at the track, I'm useaully running the motor in
the staging lane's to keep the temp up where it needs to be.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 08-21-2023, 10:38 PM
Do you monitor oil temp also?
Old 08-23-2023, 12:29 AM
blueghoast's Avatar
No I haven't done that yet
GT
