Hello Everyone,
I've had my car for 45 years and had to change the Ram Air foam seals every 6-7 years because they turn to mush and fall apart. Does anyone make these out of rubber, or a better quality foam? I know foam is correct, but I'd rather have something that I don't have to change so often. Can the rubber seal from a Camaro be adapted to fit? Has anyone come up with an alternative to the factory foam in any way? Thanks, Rick
Rick |
| The Following 2 Users Say Thank You to rickschabener For This Useful Post: | ||
before they offered repops I made some out of a sheet product called Armaflex
Its still a foam but is industrial so its much heavier.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Well the foam reproductions I am buying the past decade all seem to last and I drive often and have not had them deteriorate. Moroso sells a universal foam maybe you can get to work. But for under $100 the cost of a correct shape foam is hard to beat even if it lasts only 5 years for you.
