Did you arrive at TDC by taking measurements at .050" before and after TDC adjusting your wheel to arrive at true TDC? After you establish true TDC then you need to find the ICL by the same .050" before and after ICL and record the measurements. Then you can finally figure out whether your cam is advanced and by how much.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Here's a link to How To Degree Cam
You will need a dial indicator and the degree wheel at a minimum. What you have done is basically finding the TDC. Next would be finding the cam open/close specs and where they are at on the degree wheel.
| Closed Thread |
