Old 08-31-2023, 10:41 PM
Shiny Shiny is offline
Thanks to you both.
I now have a "custom" latch that is working well!
I concluded my latch had a difficult childhood so I spent some quality time with pliers, vice grips, and a hammer after a visit to the hardware store.
I straightened the arm, bent the "u-shaped" end of the arm to reduce clearance between the arm and the pawl/fulcrum, and bent the frame to allow a little more travel for the safety arm:
This is where I wanted to reduce clearance:
Finally, I found a flanged plastic bushing at Ace Hardware that I put in the rod hole to tighten it up:
If this proves problematic, I may have to roll over and buy a repro latch but for now, I'm good with it.
Mike
ID:	619219   Click image for larger version
ID:	619220   Click image for larger version
Old 08-31-2023, 11:20 PM
It'll probably last forever.
Old 09-01-2023, 10:38 AM
I'll be happy if it survived overnight!
Thanks again for another valuable PY assist!
I clearly enjoy learning the details of all these old mechanisms. For me, this latch is another tribute to the glory days of American manufacturing. Nostalgia!
Old 12-05-2023, 06:40 AM
1968GTOGary 1968GTOGary is offline
had the same problem mine was bent as well, the safety latch would not release. I end up sawall it in half. and buying a new repo couldn't be happier. it was always a pain to open the hood. Gary
Old 12-21-2023, 02:06 PM
Red Box Rebel Red Box Rebel is offline
My hood has always gotten stuck and the solution for me has been to:
(1) Make sure hood is fully closed;
(2) pull hood release, if hood does not pop all the way up; (see step three)
(3) While Pulling on hood release, press hood slightly down from half popped up position.
This will allow you to pull the hood all the way up from the half-popped position.
Been using this technique for the last fifty years. Always works.
Old 12-21-2023, 02:07 PM
Old 12-21-2023, 03:27 PM
I think that's actually the normal way to open. Pulling the release opens it only to the safety latch, press down slightly and pull the latch to fully release.
Old 12-21-2023, 06:42 PM
tstroud tstroud is offline
Mine is original and pulls pretty easily. One firm pull and it goes past the safety catch and you just lift it up. It took a lot of adjusting to get there. A weak pull will stop at the safety catch.
Old 12-21-2023, 10:00 PM
Exactly the way mine functions tstroud..
Mine stuck for years after the repaint. I finally got tired of it and fixed it by squaring the hood opening. Measured from corner to corner and got the measurements equalized. After that it worked properly.
Old 12-24-2023, 10:26 PM
VCho455's Avatar
VCho455 VCho455 is offline
I went through days of toil and trouble on a 68 several years ago. After all the possible options were expended we ended up cutting a 1" x 2" hole in the hood above the latch. With access from above and a big screw driver we were able get the hood open. Once open we swapped different latches but the latches ended up not being the culprit. After hours of comparing the 3 latches we had and blueprinting, what looked to be the best latch, no progress was made. So we looked elsewhere for the problem.
In the end the was problem was the fixed box (?) (See photo) in the hood that the latch hooks into had come loose. The spot welds had failed and when the hood closed the box would slide over and no amount of movement in the latch would unlock the hood. Once the box was positioned in its original location and secured with a screw the hood opened like it was brand new.
Old 05-31-2025, 04:17 PM
GameWarden GameWarden is offline
Hello Shiny.... I was advised you replied to my post, but I can't find it. Not very good at all this just yet. The hood problem has given me a fit and I worked on it for an hour this morning. I am 84 years of age, but I had to get much younger and crawl around underneath, where I found absolutely NOTHING of use. Ha, ha, just got the car and can't even open the damn hood. I will go back out and try the Paul Bunyon approach. Hope this gets to you. Thanks. Richie
Old 05-31-2025, 04:31 PM
Hello again, for my 2nd post to you. Sorry, I did not even explain what the problem is: The 'Rod' under bumper does allow the hood to come up @ 1 inch off the 'Safety latch' but putting my fingers inside this one-inch opening does not locate any other latches as in a normal vehicle. The latch to allow the hood to freely open all the way up is about 6 inches back from the 1 inch opening. I tried pushing the latch that I can see with a long-handled screwdriver but it did not work. Thanks. Richie
Old 05-31-2025, 04:40 PM
I replied by sending you to this thread!
Sorry it's giving you trouble.
Sounds like it's hanging on the safety release. In these cars, the safety, or secondary release is also actuated by the rod. There is no other latch to release by slipping your hand under the hood.
Read through all the posts in this thread for ideas, but in general, after the initial release, push the hood back down about 1/2 inch. While the hood is down, pull hard on the release rod and hold it out as hard as you can while trying to lift the hood.
If this doesn't get it, read through to understand what you are battling and get some ideas.
Good luck!
Old 06-01-2025, 12:11 AM
Yes, I had read all the previous posts but yours helped me out the best (: I was able to get the hood OPEN, Yea! I then cleaned everything and coated it with firearm silicone grease. I held my breath and locked the hood. It did not open at first but after another 5 minutes or so I heard the secondary latch move and I pulled up hard on the hood and it opened a second time Now I have an idea how the crazy mechanism works. However, I will leave it open until the State Farm Insurance representative comes over and inspects the car and takes photos in order for me to have historical car insurance in the $50K range. Good job, Shiny
The Following User Says Thank You to GameWarden For This Useful Post:
