Old 09-10-2023, 03:43 PM
Tim Corcoran's Avatar
Default Mystery Solved
Vacuum port on the runner for #3 cylinder? A big-enough vacuum leak can make the mixture too lean to burn.
Schurkey was spot on in post number 14. I suspected a vacuum leak from the very beginning but for the life of me couldn't figure out where it could be. I even pulled the carb off and made sure the gasket was covering all the right places. I believe I did all the correct trouble shooting steps but just couldn't figure it out until I pulled the intake manifold. When I was elongating the pushrod holes so I could use 1.65 rockers I got kind of carried away and broke through in a couple places. My machinist gave me some two part putty epoxy and he said it would be fine. Maybe I sanded it too thin but obviously it didn't hold. Now I need to fix these holes with something that will stay put.
Name:	Number 3 mystery.jpg
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 09-10-2023, 03:49 PM
Gach's Avatar
Gach Gach is offline
Yep that picture explains it all. That baby is sucking in some oil ( Big vacuum leak )
Old 09-10-2023, 03:54 PM
Gach's Avatar
If you can, put a sleeve down that hole, only because the Apoxy is a hit or miss. It’ll come out again when you lease expect it
