Old 09-18-2023, 10:45 PM
Trevor78 Trevor78 is offline
Some simple tests, that don't tell much, is to disconnect the sender wire at the trunk harness. With ignition, the gauge will max out, and without power, should stay there. Plugged back in, when working normally, it would pull back down to correct level. Normally.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 09-18-2023, 10:47 PM
grd777 grd777 is offline
k thanks will give it a shoot
