You stated that the flywheel was brand new. Don't assume that it was surfaced correctly from the factory.
Several years ago I had a similar issue, difficult to place the trans into first gear, grinding going to reverse. Everything was Brand New, Autogear M22, Hurst shifter, fork, throw-out bearing, clutch disc/PP, and Hays flywheel, all new. Tried everything I could think of to the fix the issue, adjustable throw-out bearing, adjustable pivot, different clutch linkage, nothing worked. Finally, after a couple thousand miles of putting up with the gear grinding, I decided to change the clutch and pp to a different manufacturer. I doing so I also figured that I would take the NEW Hays flywheel to the local machinist and have it resurfaced, for the hell of it. Turns out the flywheel surface was WAY off, not close to being true. That was my issue the whole time, even with the clutch depressed, the high point of the flywheel was touching the clutch disc at every revolution, just enough to keep the input shaft slowly spinning causing the gear grinding in reverse and the difficulty going into 1st gear. So don't assume the new flywheel is true.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
Very true on the surface, and to add to that, balance too.
I've never seen one so far out on surface runout to cause dis/engagement issues, but it could happen. .
[QUOTE="QUICK-SILVER";6457711]Any chance the splines on the pilot shaft are bottoming out against the pilot bushing?
I considered this too. I put grease on the nose of the input before installing the trans as always. It was dark moly lube type. When I took the trans out yesterday I looked at it and there was a "ring" of grease about midway or maybe a little further up towards the trans on the nose which told me it was not jammed all the way into the pilot bushing. I also test fit the bushing on the input nose to make sure it was not tight and when I drove it in I made sure it was in as far as it could go. It was flush with the hole in the crank. Quote:
... Last edited by abefromen; 09-29-2023 at 11:50 AM. |
[QUOTE=abefromen;6457741]
With mine, I could put the trans in 1st gear, but had to be VERY forceful with it. With engine not running it went to 1st easily. Reverse grinded everytime. The machinist said that the flywheel was one of the worst he ever saw, and it was a brand name Hays, so yes, an offshore flywheel could be an issue. For nearly two years I tried everything to fix the issue. Had the trans out several times, different height throw-out bearings, forks, linkage, etc. Tried anything to get more of a disengagement, and I did get more, but it was never enough to fully cure the problem. I did use a different clutch/pp, but the issue was the flywheel. The original clutch/pp went into a different car soon after and had no issues. Now I'm not going to say that the flywheel is definitely your problem, but just pointing out that you shouldn't overlook it.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto Last edited by Singleton; 09-29-2023 at 12:01 PM. |
[QUOTE=Singleton;6457747]
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
[QUOTE=HWYSTR455;6457786]Definitely, but if the input shaft starts turning again after going to 1st because of a partially engaged clutch disc, it's still going to grind in rev.
My reverse gear and reverse idler were in surprisingly good shape. Trans is original to the car with 104K on it. I've seen some on Muncies ans ST10's that were really chewed. |
