Old 10-03-2023, 10:32 AM
wakesupremo wakesupremo is offline
Thanks for the replys. Sorry steve25 but I was certain that was what I bought. Its a high rise single plain that was for fuel injection but i made plugs and filled the injector holes!!!!
Old 10-03-2023, 01:16 PM
Gach's Avatar
Gach Gach is offline
If you dyno it with a 1050, and he said you needed a colder plug, then went with colder plug then change to a 850. You probably dropped a good 30 hp and now that colder plug may need a hotter plug. Because it changes the air to fuel ratio. Only way to really tell is to make a run, shut it off and pull plugs and see what they look like. If you can take a picture of the plug I can tell you right away if it to cold can also tell if its got enough timing. I’m curious why did you take the 1050 off and put 850 on.
Old 10-03-2023, 09:43 PM
RH152 RH152 is offline
Running on dyno then at track can use different tuning
I personally have picked up et switching from 850 to 1050.you need to make a full bore run and look at plugs
pure pontiacpowerd 86 grand am
455 eheads solid flat tappet cam 8;95 @152
HOFFMAN RACING
Old 10-03-2023, 10:44 PM
Gach's Avatar
Exactly
